Hi all i have made a fantastic new discovery the other week, it is Humbrols new liquid poly. I have been using it on my recent project, and it is absolutley fantastic as opposed to Revells contacta glue which i have pretty much always used. Liquid poly is applied via a brush which comes attached to the top of the 28ml jar, however the brush is a bit on the large side so i use a small older detail brush which works fine. I find that there is no spillage or mess when i have had some of the liquid poly being pushed out when joints are clamped all you need to do is use the applicator brush moistened with some of the liquid poly and brush it away, once dry sand smooth and you dont get any gaps. I have only just started using this stuff but from what i have acheived so far which is a nice clean build to date, then i will stick with this (pardon the pun) until somthing better comes along.
scott
					scott
