Printing resizeing
  • monica
    • Oct 2013
    • 15169
    Printing resizeing
    hi all real need some help to find or use a program in win 7 to resize pictures to use
    in dio,s i have an Epson stylus C 79 ,but im having real trouble to change the pic size down by %
    in win xp had a very simple program that i used and was able to do it
    but im realy stuck with this one and mind you im no techo so the simple the better any help plz
    Moni
    maybe this should not be hear ?
  • Gern
    • 9306
    Hi Monica.
    Just tried it on my machine with an image pasted into a word document. Right click on your image and you should get a drop-down menu. Select 'Format Picture' and look for 'Size' in the new menu. That allows you to change both height and width independently using either actual sizes or % changes.
    Gern
      Hi Monica.
      It's not a solution...just an idea... ops:
      I have a shop in the big city that said me, they can print diferent pictures, directly from some "pen drive". The advantage is the different possibilities of change the size, and "where" to print the picture!! One interesting option is on a transparent "vinyl" sheet.
      Hope this help you.
      Polux
      • monica
        • Oct 2013
        • 15169
        hi Gern / Polux thank you both for the reply,i will have a look at that way gern someone once said you can use word document.and i think its in win 7 , i use very little off what a pc can do
        as its easy to use % than pixel,s , only takes 1 try and you can work out if to big/small, thks
        thank you Polux i do have a place close at hand called offices works maybe if i load them up , they maybe able to resize once i get one set im good just keep recopying them , its just getting
        the 1 st done as i said im no techo,
        if the setting in the print program , i could use , to resize are grayed out and that the whole problem, and with word can you inport more than 1 pic at a time ?
        • Richi72
          • Sep 2013
          • 1100
          Hi Moni,
          I use pixresizer. easy to use, but if it suits your needs, its free and here's the link
          LINK and look for PIXresizer 3,0mb
          Hope this helps oh and its in English.
          Cheers Richi
            Monica, Create a PDF of the print or drawing, then when printing the PDF go into the menu and you will find that you can increase or decrease the original size. Cheers Derek
            • monica
              • Oct 2013
              • 15169
              hi Richi / Derek, thank you i will have a look at that one and see how easy it is to use , as i say im just naff with things
              and also will have a look at the PDF, as well , that should be on the PC already or is a part off adobe ?
              • Richi72
                • Sep 2013
                • 1100
                Hi Moni,
                Adobe reader is normally for reading pdf files but I think you cant make them with Adobe reader. but there are a lot of free pdf converters around the www.
                is it something special you are looking for or just a dimension change?
                I have a couple of prints on file as pdf and some I made myself. Only problem they are to big to post them here.
                let me hear if you need help.
                Cheers Richi
                  Monica, I had to buy a new computer about 2 years ago with Win 7, not mentioned anywhere in the documentation is a program called PDF Complete you will find in in the main 'C' directory under Apps. Load this and you can then create a PDF. Then using the free Adobe Reader open the PDF document you just created with the Adobe Reader and then go to the menu, select custom, and dial up the magnification/reduction you need, then print to your normal printer. Cheers Derek
                  • monica
                    • Oct 2013
                    • 15169
                    thanks guys will have a look into it , well Richi , if i post my email will they fit in a doc for that,
                    the type off things i wont to scale down are road sighs , and poster like these, wallpaper, as i do most things on a budget ,if you get what i mean
                    [ATTACH]77574.IPB[/ATTACH]
                    [ATTACH]77575.IPB[/ATTACH]
                    [ATTACH]77576.IPB[/ATTACH]
                    [ATTACH]77577.IPB[/ATTACH]
