RESIN HELP.
  • eddiesolo
    • Jul 2013
    • 11193
    RESIN HELP.
    Hi guys I am putting together a 1/1 scale resin blaster from Lost In Space, it was supposed to be from the original series but is in fact from the movie.
    Here is the question: The pieces are heavy and I know to use superglue or two part epoxy, what I want to know will that be strong enough or shall I drill and dowel? If using dowels will the wooden type be okay or shall I source some plastic?
    Any help appreciated, thanks.
    Si
    • 18272
    Hmmm. If I thought it was needed I would drill and wire. Brass wire probably the safest bet. To get around any alignment problems I make one set of holes a bit bigger than needed.
    Wiggle room I call it.
    I will say though that it is (IMHO) only needed for things that need structural strength.
    Pinning can be a pain if the holes do not line up....
    • eddiesolo
      • Jul 2013
      • 11193
      Originally posted by \
      Hmmm. If I thought it was needed I would drill and wire. Brass wire probably the safest bet. To get around any alignment problems I make one set of holes a bit bigger than needed.Wiggle room I call it.
      Nice one Ian, thank you. I have learned two things with working with resin. One: it gives off a lot of powder, hence you telling me to wear a mask, and two: it may seem heavy and hard but it you're not careful you can sand chunks away...more filler needed when assembled. Will have a go and see how it performs before I start to drill and faff.
      Si
      • Gern
        • 9245
        Definitely metal pins if you decide they're needed Si. Unless you look for really hard plastic - which is likely to be MUCH more expensive than a bit of brass/steel rod - you could end up making the joint weaker.
        You can get steel pins from just about anything, but large paperclips are a good source. I used some 1.6mm diameter welding rod on my 'Bug'. If you want some, send me a PM with your address and I'll pop some in an envelope for you.
        Gern
        • Dave W
          • Jan 2011
          • 4713
          I use panel pins if I'm after structural strength.They can be cut to length with pliers and are cheap (if you don't go to B&Q).
          • eddiesolo
            • Jul 2013
            • 11193
            Definitely metal pins if you decide they're needed Si. Unless you look for really hard plastic - which is likely to be MUCH more expensive than a bit of brass/steel rod - you could end up making the joint weaker.You can get steel pins from just about anything, but large paperclips are a good source. I used some 1.6mm diameter welding rod on my 'Bug'. If you want some, send me a PM with your address and I'll pop some in an envelope for you.
            Gern
            Thanks Dave will let you know if I need some, and thank you for the tips, I was looking at plastic but after thinking about it, it was too flimsy and I figured it would just cause a weak area, as you pointed out.
            Si
            • eddiesolo
              • Jul 2013
              • 11193
              Great stuff Dave, appreciate it. Going to start assembly later today after finishing and sanding so will see how it goes.
              Si
