Help with wiring
    Help with wiring
    Wiring my dio for the GB & need to know whats the best way.
    [ATTACH]78594.IPB[/ATTACH]
    It will be running off 12v scalextric power unit so there will be no power drain,
    it seems to be brighter with the top diogram but is this the right way to do it.
    Thanks
    • 18272
    What type of lamps are they?
      Expo Grain Rice 12v Clear.
      • Richi72
        • Sep 2013
        • 1100
        Hi John,
        I will go with the first one, all lamps directly at 12V they would shine brighter as the second one.
        Cheers Richi
          Ok Richard i will go with thay one then.
          • flyjoe180
            • Jan 2012
            • 12565
            • Joe
            • Earth
            Yeah, I'd run them in parallel rather than in series. That way if you have one go the others won't stop. So option A.
            • eddiesolo
              • Jul 2013
              • 11193
              Yep, A seems the way to go. As Joe points out if one fails then they will carry on working.
              Si
