Vaughn: Your spraybooth looks very like mine. I use the fishtail end of the hose shoved in the partly open window (like the leaflet says). But it looks like you have a brick wall behind your booth. How do you exhaust it?
					Newly promoted workstation!
	 Guest Guest
 I take it your daughter's not planning on coming home then.... Great set-up, and as John mentioned, a very nice collection of models. Do you keep your stash in a separate room? Great set-up, and as John mentioned, a very nice collection of models. Do you keep your stash in a separate room?Comment
 Mike I think your right there, she's the last one to leave so it's nice to be able to use the room for something useful as a pose to another spare bedroom the stash is under the stairs that leads to the loft. Steve I'm not sure what I'm going to do as far as venting the spray booth. It's not been used yet so will have to work that one out the window is on the opposite wall.Comment
 Nice one. I don't even have a corner in a shed, all my stuff is packed away and I have to get everything out and set it all up each time I want to do some work on a model  Comment
	 Guest Guest
 You are not alone mate, I have to do that as well.....
 Originally posted by \Nice one. I don't even have a corner in a shed, all my stuff is packed away and I have to get everything out and set it all up each time I want to do some work on a model Comment
 right thats it. im dragging my lazy step son down to the army recruitment office. that bedroom will be mine!Comment
	 Guest Guest
 Dave that could be an idea not sure where you would get one from or what they look like.Originally posted by \Hi Vaughan.Just a thought on venting your spray box. Would a condenser box that is used for tumble dryers work?
 Gern
 Still in the early stages of settling in here so will have to experiment where things will go.Comment
 Hi Vaughan. This is the kind of thing I was thinking of:Originally posted by \Dave that could be an idea not sure where you would get one from or what they look like.Still he early stages of settling in here so will have to experiment where things will go.
 http://www.ebay.co.uk/itm/White-Knight-Universal-Tumble-Dryer-Indoor-Condenser-Vent-Kit-Box-With-Hose-/150920641871?pt=UK_Irons_Presses&hash=item2323923d 4f
 As far as I know you add a small amount of water which acts to condense the water out of the air from the tumble drier. I just thought that might absorb any particles of paint from your spray booth - especially as you use acrylics - although you might need to use some tissue or similar around the outlet vent of the box to catch any paint that doesn't get caught in the water.
 GernComment
	 Guest Guest
 Hmmm. Not sure a condenser would work. When the (liquid) solvent in enamel and lacquer paint comes out of the AB nozzle, some lands, as liquid, on the model with the paint, but some must evaporate (else why the smell or the need for a spraybooth). At normal room temps. and air pressure, the evaporated solvent (white Spirit or Cellulose Thinners) will remain a gas, and the only way to condense it to a liquid would be to cool it to its condensation temp. Certainly, for white spirit and cellulose thinners, that temp. is below normal room temp., so it would probably not condense in a simple clothes dryer condenser, especially before it was blown out of the condenser. (The condenser must obviously have its own vent to allow a through current of air).Originally posted by \Dave that could be an idea not sure where you would get one from or what they look like.Still he early stages of settling in here so will have to experiment where things will go.
 With acrylics, which are water based, if the smelly stuff is also water based, then perhaps it would condense. After all, water vapour from a clothes dryer does condense otherwise the condensers would not work. But acrylic paint might contain other solvent-like chemicals (mixable with water of course) which have a condensing temperature below room temp. (Smelly things are like that.)
 We have a dehumidifier which reduces condensation in one of our rooms. It works by blowing the room air through a mini refrigerator (which is why they are quite expensive). The water in that cooled air condenses out into a tank. So that indicates even if acrylic paint solvents were like water, you would probably need a refrigerating condenser.
 I think I saw a statutory statement somewhere that said the acrylic modelling paints were not hazardous to health. So why a spraybooth in the first place? Perhaps just to prevent smelling out the house? A clothes peg on the nose might be a cheaper solution (for acrylics)!Comment
	 Guest Guest
 Had a similar problem in my room Vaughan. I bought extra ducting coupled the two up. Gives about 10 feet in length. If you do not want it trailing around it concertinas into next to nothing. Stiil works perfectly even with the extra length.
 I also built a little table just a bit larger than the spray unit. A bit nearer the window and also kept all the paint stuff away form my work top.
 Edit. Depends on the manufacturer of the Acrylics Steve. Some have solvents not water based. Even Vallejo which is said by Vallejo Model Air to be OK. But a number of the paints have warning on them as having chemicals which are not healthy.
 Plus put a dob of Vallejo thinners on plastic. It dries with a residue. That residue I am not to keen on drifting down my throat into my lungs.Comment
	 Guest Guest
 Vaughan you can get the optional kit with hose at £14:95 on Amazon.
 Alternative you can get from B & Q and Builders merchants an oblong section about 4*2 inches which can be parked along side a skirting. There are joints which convert round hose to oblong. Gives a much better look and does not affect the working state of the ventilation.
 LaurieComment
