BMW R80 restoration
  • Ancientmariner
    • Feb 2018
    • 867
    #46
    So heads and rocker covers on finally. Need a new front end bearing and then get the front end on in the next week hopefully.
    • Mark1
      • Apr 2021
      • 4156
      #47
      My dad had a bmw, the sidecar was the first mode of transport i remember being carted around in, with my mum ,younger brother and the dog.lol
      Sidecar something similar to this.Click image for larger version
        Just had a read through James, looked a massive task to undertake.
        You certainly have the skill , most impressive work .
        • Ancientmariner
          • Feb 2018
          • 867
          #49
          It's a complete bodge job John, will probably never work again but at least it will look nice
          • scottie3158
            • 14635
            • Holbeach
            #50
            james,
            Just had a catch up. Your doing a great job, but I must say I'm jealous of your garage.
            • adt70hk
              • Sep 2019
              • 10552
              #51
              James coming on very nicely.
              Out if interest do you have to tell the DVLA about what bodywork there is and the tank changing colour?
              ATB.
              • Ancientmariner
                • Feb 2018
                • 867
                #52
                james,
                Thanks, it's taken years, it is VERY small but space is well utilised
                • Ancientmariner
                  • Feb 2018
                  • 867
                  #53
                  ATB.
                  DVLA will need to be, as frame has been heavily modified as well, tank colour will change so though a lot of it is the same it will be a different bike basically
                  • Ancientmariner
                    • Feb 2018
                    • 867
                    #54
                    Sidecar something similar to this.[ATTACH=CONFIG]n1198833[/ATTACH]
                    Love the side car!!
                    • Ancientmariner
                      • Feb 2018
                      • 867
                      #55
                      Looking forward to having something more upright to ride as all my other bikes are sports bikes
                      • Ancientmariner
                        • Feb 2018
                        • 867
                        #56
                        Front end bearing heated and on and likewise with front cover. Though just discovered stainless hex bolts don't fit which is annoying.
ID:	1199118Click image for larger version
ID:	1199119Click image for larger version
                        • Ancientmariner
                          • Feb 2018
                          • 867
                          #57
                          So engine is pretty much done, just rebuilding carbs, got spark plugs to go in once delivered and then got to fit clutch and also strip and rebuild the gearbox.
                          Started stripping the forks as well today, going to repaint them and then rebuild them. Also got to get the wheels powder coated once I have got the bearings out.
ID:	1209227Click image for larger version
                          • Waspie
                            • Mar 2023
                            • 3488
                            #58
                            Just had an enjoyable period reading all of this rebuild. Brought a few memories back. I could almost smell the old engine oil at one point. Nice to see it coming to fruition James. Most excellent thread.
                            • Ancientmariner
                              • Feb 2018
                              • 867
                              #59
                              Thanks, glad to see it provides enjoyment.
                              As far as "fruition" goes I've possibly been a bit over optimistic there, likely a few years yet. Though I think I am going to bench test the engine as it is just to see if it runs rather that bolt it in and find it doesn't.
                              I think the wheels being redone will be a major milestone personally.
                              Have you rebuilt any of these? I'm always after advice from anyone who has.....
                              • Ancientmariner
                                • Feb 2018
                                • 867
                                #60
                                After an annoying period getting spares and finding they are wrong I decided to make a start on something anyway.
                                Stripped one of the suspension struts today.
                                Some rust on the stainless section I was pleased came away with use of 800, 1000, 1200 and then 1500 emery cloth and hasn't pitted. £152 saved there which was a big relief (also the difference between the project carrying on and not carrying on).
                                Internally all good. Top seal destroyed as expected so will need new ones of those, fork oil and that's it. Dust seals good after a clean.
                                Going to sand, spray and clear coat the forks before reassembly and make them look a little more snazzy.
                                Also interestingly there's a top adjustment feature which does no adjusting as the thread doesn't locate into anything. Wonder if they have been bodged at some point?
                                Nice to have done something on a day I lacked motivation!
ID:	1210001Click image for larger version
ID:	1210002Click image for larger version
ID:	1210003Click image for larger version
