FW190 E8.......Revell 1/72
  • PaulTRose
    • Jun 2013
    • 7121
    • Tattooine
    my entry for the gb
    No idea how old it is but the last time i saw this much flash Queen were singing the soundtrack! 🤣
    Going to what sort of job i can make of it but im way out of my comfort zone
    You may only view thumbnails in this gallery. This gallery has 2 photos.
    Per Ardua
    • 16204
    That kit has got to be 25 years old. Interesting to see how you get on.
    • colin m
      • 9043
      • Colin
      • Stafford, UK
      How nice of Revell to give you all that spare plastic.
      • yak face
        • Jun 2009
        • 14268
        • Tony
        Its a nice kit paul once youve cleaned the flash off. Just a couple of areas to watch out for - be very careful cutting the engine fan off the sprue , the blades are very fragile , and watch out removing the nose ring section , the sprue gates overlap onto the front surface and its a careful clean up . The cockpit is quite good but you dont get the option to have an open canopy as the rear sliding section is moulded as part of the fuselage. When I did mine I cut this off and used a spare Airfix canopy . Whatever I’m sure it’ll be a great build , cheers tony
          • 19106
          Flashtastic mate……sure it will clean up well though…
          • Geoffers
            • Jan 2017
            • 2116
            • Geoff
            Definitely an oldie 🤞 it’s a golden one for you 😉
            Good luck with your build.
            Geoff.
            • scottie3158
              • 14591
              • Holbeach
              Paul. I'm in
              • HAWKERHUNTER
                • Feb 2012
                • 2047
                • Steve
                • Halifax, West Yorks.
                I am sure you will fettle this one into shape Paul.
                • Valeron
                  • Jan 2022
                  • 966
                  • Mike
                  • St Albans
                  Ill ne watching. Good luck with this oldie.
                  • PaulTRose
                    • Jun 2013
                    • 7121
                    • Tattooine
                    Fuse and wings together
                    Needed some filler so should be dry tomorrow.....let the sanding commence
                    Per Ardua
                    • Geoffers
                      • Jan 2017
                      • 2116
                      • Geoff
                      That’s good progress Paul, taking shape nicely 👍
                      Geoff.
                        • 22957
                        Nice start Paul.
                        • Tworrs
                          • Jan 2022
                          • 1982
                          • Garry
                          • New Zealand
                          Looking good Paul.
                          • PaulTRose
                            • Jun 2013
                            • 7121
                            • Tattooine
                            Had a few days off so no progress but ive had an idea......i fancy trying to do it 'in flight'
                            So im going to have a go at making a stand before i do anything else.......in case it dont work in which case it will get wheels attached 🤣
                            Per Ardua
                            • PaulTRose
                              • Jun 2013
                              • 7121
                              • Tattooine
                              Mistake cant delete
                              Per Ardua
