Geoffs Revell 1/72 Fw 190 A-8 & BV 246 “Hagelkorn”
  • Geoffers
    • Jan 2017
    • 2178
    • Geoff
    Well here we go with my entry.
    Click image for larger version  Name:	IMG_3976.jpg Views:	82 Size:	347.9 KB ID:	1245023
    I don’t build Luftwaffe kits as a rule but wanted to join the GB as a tribute to Alan, I hope I can do it justice 🤞.
    This kit is from the 1990s when Revell were knocking out some decent kits and this looks to be no exception 😊
    Here’s the plastic.
    Click image for larger version  Name:	IMG_3977.jpg Views:	75 Size:	287.3 KB ID:	1245024 Click image for larger version  Name:	IMG_3978.jpg Views:	76 Size:	292.2 KB ID:	1245025
    Click image for larger version  Name:	IMG_3979.jpg Views:	77 Size:	321.1 KB ID:	1245027Some nice refined surface details.
    Click image for larger version  Name:	IMG_3980.jpg Views:	77 Size:	245.1 KB ID:	1245028 Clear parts.
    Click image for larger version  Name:	IMG_3981.jpg Views:	77 Size:	583.2 KB ID:	1245029
    Instructions - Old skool Revell 🙄
    Click image for larger version  Name:	IMG_3982.jpg Views:	77 Size:	238.6 KB ID:	1245030
    Transfers - no Swastika’s
    Now a bit of history from Revell:
    “During World War II, the Focke Wulf Fw 190 proved to be the
    most versatile single engined Luftwaffe aircraft.
    Over the years the fighter-interceptor became a fighter-bomber, torpedo
    bomber, fighter and two-seater trainer. In addition the Fw 190
    was increasingly used for testing complete weapons systems at
    the Luftwaffe proving stations. Thus various versions came to be
    used for testing the Blohm & Voss Bv 246 „Hagelkorn".
    The Bv 246 was an automatically controlled glide bomb which was
    originally developed to replace the Fieseler Fi 103 (better known
    as the V 1). The Junkers Ju 88 A-4 was designed as a transporter
    which would carry up to three of these machines in action. Howe-
    ver during trials aiming was not sufficiently accurate and the
    programme was discontinued for the first - but not for the last
    In July 1943 the Karlshagen proving station received an order to
    test the Bv 246 which started with a Ju 88 and after that was lost it continued with the Fw 190. However the planned production
    was interrupted several times, until finally there only remained a
    series as target practice for the anti-aircraft guns. Between July
    1943 and July 1944 a total of about 238 Bv 246s were tested with
    different control systems.
    Testing with the Fw 190 and Bv 246 was abruptly halted in Karls-
    hagen when all the remaining 29 Bv 246s were destroyed in an air
    attack.
    A total of 1,100 type Bv 246s were built.
    Span 6.41 m, Length 3.53 m, Diameter 0.542 m, Weight 730 kg,
    Explosive charge 430 kg”
    Hoping to get started soon, thanks for looking 👍
    Geoff.
  • Steven000
    • Aug 2018
    • 2948
    • Steven
    • Belgium
    Great to see you make an exeption for Alan Geoff, looks good 🫡
    • Geoffers
      Geoffers commented
      Editing a comment
      Cheers Steven it does look like a good little kit, hopefully it goes together well too 🤞
    • 16311
    That some very interesting background Geoff. Looks a nice kit. Revell kits are quite varied in quality but this looks more than ok. Let's hope the fit is good.
    • Geoffers
      Geoffers commented
      Editing a comment
      Thanks Jim, yes I’m keeping my fingers crossed 😊
    • 19134
    Nice! Interesting variant as well…..
    • Geoffers
      Geoffers commented
      Editing a comment
      Thanks Tim, I was surprised how many roles the Fw 190 performed 🤔
  • PaulTRose
    • Jun 2013
    • 7261
    • Tattooine
    This is identical to my kit....i even get the un needed glide bomb
    thing is you didnt get the flash i got 🤣🤣
    Per Ardua
    • Geoffers
      Geoffers commented
      Editing a comment
      You mean you didn’t specify the flash free version when you purchased yours Paul? 😂
  • pjgtech
    • Dec 2023
    • 1462
    • Peter
    • Swale Kent UK
    Nice looking kit, just started a plane build myself.... good luck with yours. 8-)
    • Geoffers
      Geoffers commented
      Editing a comment
      Thank you and good with yours too 👍
  • Tworrs
    • Jan 2022
    • 1982
    • Garry
    • New Zealand
    I'll follow along Geoff.
    • Geoffers
      Geoffers commented
      Editing a comment
      Glad to have you along Garry 👍
  • HAWKERHUNTER
    • Feb 2012
    • 2074
    • Steve
    • Halifax, West Yorks.
    Nice one Geoff
    • Geoffers
      Geoffers commented
      Editing a comment
      Cheers Steve 👍
  • yak face
    • Jun 2009
    • 14309
    • Tony
    Nice choice geoff , its not a bad kit at all , cheers tony
    • Geoffers
      Geoffers commented
      Editing a comment
      Thanks Tony, that’s good to know 😊
  • Nicko
    • Apr 2019
    • 1682
    • Nick
    • East Anglia
    Interesting addition with that glide bomb Geoff. Must have made take offs more difficult though. Following along....
    Nick
    • Geoffers
      Geoffers commented
      Editing a comment
      Cheers Nick 👍
      Yes it must have been a bit unwieldy but not as bad as with a torpedo which I believe they carried 😮
  • Geoffers
    • Jan 2017
    • 2178
    • Geoff
    Well I’ve made a bit of a start today 😊
    Cockpit parts cleaned up and painted in the base colour.
    No decals for the instrument panel and side consoles so some detail painting required 😱.
    I’ve ordered some photo etch seat belts which should hopefully arrive soon.
    I’ve also put the glide bomb or Hagelkorn together which Google translate informs me is German for Hailstone.
ID:	1245185 It will need a bit of tidying up before painting.
    So not too much done but once the cockpit is done it should be 🤞 a fairly straightforward build.
    Thanks for looking 👍
    Geoff.
    • yak face
      • Jun 2009
      • 14309
      • Tony
      ‘Thanks Tony, that’s good to know 😊‘
      Cheers geoff , as I mentioned to paul ( hes doing the same kit but without the hagelkorn) just watch out for the engine fan and nose ring section , they need very careful cutting from the sprue , and the nose ring is a bugger to clean up due to the sprue attachments overlapping the surface .
      • Geoffers
        Geoffers commented
        Editing a comment
        Cheers Tony, I’ll pay extra attention to those parts 👍
      • 22983
      A cracking start Geoff.
      • Geoffers
        Geoffers commented
        Editing a comment
        Thank you Ian 👍
    • HAWKERHUNTER
      • Feb 2012
      • 2074
      • Steve
      Good start Geoff
      • Geoffers
        Geoffers commented
        Editing a comment
        Cheers Steve 😊
    • flyjoe180
      • Jan 2012
      • 13103
      • Joe
      • Earth
      Looks like an interesting subject Geoff. Good start on the FW190
      • Geoffers
        Geoffers commented
        Editing a comment
        Thanks Joe, yep it’s a bit different isn’t it 😊
