Dave W's BAC Lightning
  • Dave W
    • Jan 2011
    • 4713
    #16
    Originally posted by \
    Looking good.There are several good photo's in this months 'Flypast' magazine that may be of interest Dave.
    Just so happens I bought 'Flypast' yesterday.I was attracted by the Lightning on the front cover
    • flyjoe180
      • Jan 2012
      • 12938
      • Joe
      • Earth
      #17
      Looks good Dave. Minimal filler I see, a nice change for you
      • Dave W
        • Jan 2011
        • 4713
        #18
        Most of the parts fit quite well on this kit.Although I did have a bit of trouble getting the cockpit tub to sit right.
        • Dave W
          • Jan 2011
          • 4713
          #19
          I've spent the last two evenings painting the Quickboost resin seat.I must say it is a superb molding.Ive done my best to paint it using photos off the web.As for the model,it's almost at the painting stage.I need to replace the gun sight plastic with a piece of clear plastic.Then I will mask and fit the windscreen.Ive applied a bit more filler to the spine and will need to rescribe a few lines.This is a great kit of a great aeroplane and I'm really enjoying building it.Highly recommended.
          • flyjoe180
            • Jan 2012
            • 12938
            • Joe
            • Earth
            #20
            Super work Dave. Sure is a lot of straps on that seat.
            • colin m
              • 9019
              • Colin
              • Stafford, UK
              #21
              Looks great Dave. I wanted to do the same model, but time is against me. I'll have to watch your build instead.
              • Dave W
                • Jan 2011
                • 4713
                #22
                Nearly ready for paint now.I've decided to have the canopy closed so it's now masked and glued on.Im going to do a 23 sqdn machine with white spine and fin.Will spray the white areas first then mask and spray the rest of the model with Alclad black primer.Dont know if the Alclad will react with Vallejo primer.So I will have to try it on a test piece first.
                  • 18301
                  Good idea to try the primer on a scrap piece first. I am a bit worried that the one will eat the other..
                  If it is all primed, it might be better to spray a gloss black enamel then the alclad onto that. I know others have use alclad on top of gloss enamel with good results. Again try it first!
                    Nice subject, looking for more.
                    Francesco
                    • flyjoe180
                      • Jan 2012
                      • 12938
                      • Joe
                      • Earth
                      #25
                      Looks good Dave. Hoping this paint job turns out with no problems.
                      • Dave W
                        • Jan 2011
                        • 4713
                        #26
                        I've sprayed the undercarriage bays with Vallejo aluminium.Then I masked these and other areas ready for spraying.Ive then put a length of dowel up one jet pipe to hold the model with and sprayed a coat of primer on.Will check the model next to make sure Ive got rid of all the seams.
                          • 22950
                          #27
                          Looking good Dave
                          • yak face
                            • Jun 2009
                            • 14236
                            • Tony
                            #28
                            Looks great Dave , the U/C bays look fine to me now theyve been primed ,nice work filling the cannons too, cheers tony
                            • Dave W
                              • Jan 2011
                              • 4713
                              #29
                              There's a plain panel for the F6 instead of the cannon panels. But the cannon panel was a better fit.So I used that and filled in the gun trough.
                                That 23 squadron is very very nice in the pic you posted.
                                Good progress with the Model, and can't wait to see it wearing that scheme.
