Pink Panther's Pallet Factory (Building GB)
    Hi friends!
    This is my entry for the Building GB.
    [ATTACH]89478.IPB[/ATTACH]
    Is a pallet factory from the brand Faller at scale 1/87 (HO). His size is 404 x 140 x 185 mm. Is a new item from 2013 (ref. 130188). And is considerate an époque II item, so this means was building during 1921 – 1945.
    Is not my first kit from Faller, and must say I’m really pleasure with the quality and the final result of all them. Is more than habitual, on the train modellers, that they build directly the buildings OOB with only a few and final weathering, this is the reason the kit comes with a different colours on the sprues, inclusive with some weathering as well!. In my case I will repaint all the set
    [ATTACH]89479.IPB[/ATTACH]
    Of course this factory will be part of my train layout in a near future, so I will build it without a base or over a diorama.
    The only doubt I have in this moment is the paintwork. With a fast look, I have discovered all the walls are made of wood (the original building), so it will be a good challenge to recreate an old and damage wood all around. And I’m considering recreating an abandoned factory as well..... I want an old and abandoned building on my layout, the typical factory dirt and full of “graphities” on the walls Maybe will be this one :P
    Thanks for looking.
    Polux
  • monica
    • Oct 2013
    • 15169
    nice Polux, cannot wait to see your magic on this one, good luck
      Thanks Moni!!
      These buildings are really easy and fun to build
      • spanner570
        • 15599
        Hey amigo, that looks good.....we are up and running!
          • 22954
          It looks like a very good building Polux and I'm sure that you will do it justice
            Dear Ian!
            Is just an idea by the moment....but, can I recreate a little "scene or diorama" with one or two buildings more...?
            Or better post here, only, the under construction thread of the building, and once finished open a new thread with all the "diorama" ends? ops:
              • 18301
              I dont have a problem if the diorama has more than one building in it..
                Ok! Thanks Ian!
                Anyway, as I said, is just an idea now
                  Yep!! Here I go!!!
                  First at all, I change of plans of course.....
                  I will build it on a little base with an abandoned appearance. I’m changing my layout and this item don’t will be there
                  The colour is much better than I expect, as equal the detail...so I decided to do a weathering paintwork with enamels by the moment. This kind I don’t will lose these details with the “normal steps” - primer + paint coat + enamels for weathering....
                  The excess of paint is easy to take off with a little sponge!
                  [ATTACH]89927.IPB[/ATTACH]
                  [ATTACH]89928.IPB[/ATTACH]
                  Thanks
                  Polux
                  • flyjoe180
                    • Jan 2012
                    • 12938
                    • Joe
                    • Earth
                    That wood is looking very convincing Polux, great work so far mate.
                      • 18301
                      I second that.
                        Yep!!
                        A little update
                        Two walls glued.....
                        [ATTACH]90059.IPB[/ATTACH]
                        A pin wash.....
                        [ATTACH]90060.IPB[/ATTACH]
                        And I'm trying how the pigments works.....
                        [ATTACH]90061.IPB[/ATTACH]
                        I'm glued it wrong (without care) and the glue is so much visible.... I will retouch and correct it (paintwork) once I have builded all the model......
                        Thanks for looking
                        Polux
