This is my entry. I really like the look of this kit and this colour scheme, its a little different from the norm, however I'm going even more leftfield and doing it in the markings of the Ethiopian Air Force. I have three more Eduard Mig-21's in the stash so the GDR scheme will get done at some point. This is new ground for me, I've never built an Eduard kit before.
Rick's Eduard 1/48 Ethiopian Air Force Mig-21 MF
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Tags: None -
Guest -
Guest -
And we're off!
Some of the sub assemblies together, what a good fit so far.
Attached FilesOn the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Just finished: Airfix 1/48 Stuka & Airfix 1/72 Sea King HC4.Comment
Guest -
Eduard kits are excellent kits, with tight fit and little room for error, but their surface detail is brilliant and in general their detail is really nice. I bet you will find this a really enjoyable experience.
Looking good so far.
JohnComment
I'm a bit confused here with the cockpit decals. The instructions mention applying them to plastic but it doesn't seem clear to me if they mean the sidewalls of the fuselage moulding. I checked Patrick's build but it looks like he has used the etched metal instead of the decals.
Any advice please?
Looks to me as if the parts marked 'plastic' aren't supplied, you're supposed to make them from plastic sheet?
I've found that Eduard often have you doing this with their AFV pe setsComment
So far so good John. The kit has a certain feel about it, the quality is very good and the experience so far is quite a stretch from other kits I have built. There's a cerebral experience to it.On the bench: Airfix 1/48 Sea King HC4, Revell 1/24 Trabant.
Ive just looked at mine patrick and i think youre right , on the weekend kits i think eduard expect you to make it yourself from plastic card . what im wondering though is what you stick the pe to if theres no side piece supplied?Comment
