Bob's Tamiya 1/35 Stug IV
    Here is my second entry into this GB
    Build Plan
    I will be building the Tamiya Stug IV, without the side armour plating, the rest of it will pretty much be OOB. As for a colour scheme, I am trying to look for something basic, and not in sand colour, but most of the schemes I find all seem to have some form of camouflage pattern. Will do some more research into that. The tank will be preshaded then painted and finally very lightly weathered, once again I am going for a clean look as thats how I prefer my models.
    Kit Details
    Here are the kit details taken from scalemates.com
    Brand:
    Tamiya
    Product name:
    Sturmgeschütz IV
    Product number:
    35087
    Scale:
    1:35
    Type:
    Full kit
    [COLOR=rgb(136,136,136)]Includes: Plastic sprues, Vinyl, Waterslide decals[/COLOR]
    Released:
    1976 | Rebox [COLOR=rgb(136,136,136)](Changed box only)[/COLOR]
    Decal options
    1. StuG. IV
        Wehrmacht Heer (German Army 1935-1945)
      StuG.Brig. 237
    2. StuG. IV
      StuG.Brig. 251
    3. StuG. IV
      StuG.Brig. 279
    Scalemates link:
    https://www.scalemates.com/kits/1234...urmgesch-tz-iv
    Box Art
    Kit Contents
    Good to go
    Well I have started the kit, and am working on the wheels, I will post up photos soon.
    I hope you all liked the post, all comments welcome.
    Another golden oldie Bob! If you can, change the supplied tracks coz they're pretty bad. Some Dragon Magic Tracks would fit.
    You'll struggle to find a scheme that doesn't have a camo pattern. The StuG IV was introduced after the Germans went with the 1943 Dunkelgelb base & olivegrün/rotbraun combination.
      • 22948
      It looks a nice kit Bob.
      • Rbaker
        • Jan 2016
        • 245
        • Richard
        • Lye
        Found this site that shows two with camo that is not showing the sand base colour if it gives you nay ideas
          Thansks Ian mate.
          Thanks Patrick, I found the tracks but their a bit expensive for me, especially when I bought this kit for less than half the price of the tracks
          Thanks loads for the link Richard, Im going to go with the desert yellow and red brown camo scheme,
          Here is my first build update.
          Wheels done up and primed
          Wheels painted
          Lower hull assembled primed and preshaded with Tamiya XF-1 Flat Black enamel
          Upper Hull still being assembled
          Here it is in its current state
          That's it for this one, will complete the upper hull tomorrow, I will leave off the tools till the end, as they will be painted separately.
          My thoughts about this tank are that it is very strange looking, but tactically very clever; as it is very low to the ground, thus making it a smaller and hence harder target.
          I hope you all liked the build update. All comments welcome!
            • 22948
            It's coming along very nicely Bob
            • monica
              • Oct 2013
              • 15169
              very nice  Bob,I do like these,s one,good start and progress with this as well,
              I pickup one at the lastt swap meet ,I went to,so should real start itt,as we only have 4 wks with this one,
                Thanks Ian and Moni,
                Lots of work done today. Most of it was on the wheels about close to 5 hours all on just the wheels. Each wheel took ages to paint. Here is the build update.
                The longest journey starts with a single step
                All the wheels done finally - painting those rubbers on the wheels took its time. I used a black marker along the edge of the inside to get it as circular as possible. I used Tamiya Acrylic paint XF-1 Flat black over the enamel Dark Yellow. I cleaned up any excess with Windex.
                The lower Hull was painted and assembled
                I broke off one of the wheel holders by applying too much pressure. I cannot find where the broken part is, I will look again tomorrow, might have to scratch build some kind of wheel holder there.
                I primed the upper hull with Tamiya white primer and then pre shaded it with Tamiya XF -1 FLat black enamel paint
                This was then painted with Tamiya XF-60 Dark Yellow enamel paint. The pre-shading came through so very happy with that! Here it is for now
                Next up I will apply the red brown paint - free hand camo then will do up the tools, spare tracks and antenna. I might decide to do up the figure, havn't decided yet.
                I hope you all liked the build update. All comments welcome.
                  I can't save you the time & trouble of cleaning up the wheels on a P  IV chassis Bob, but there's an easier way to paint them if you've got an airbrush.
                  Spray each wheel black/dark grey on the tyre section. Don't worry about getting it too neat.
                  Then use a circle template to spray the face. The one I have is made by Helix, but other manufacturers are available
                  It gives perfect wheels every time.
                  Your pre-shading worked well, I've pretty much given up doing that. I find it easier to add high & lowlights using oils further down the line. Having said that, I might try the black & white pre-shading method on my Ferdinand
                  • monica
                    • Oct 2013
                    • 15169
                    very nice work Bob,looking good,sorry to hear you broke/lost , :S
                    the way that Patrick,said for doing wheels,is the same way I,do them,with the,circle template,and then very easy to
                    to touch up if needed,
                    will look forward to seeing the camo go down,
                      Thanks for the info there Patrick, I am checking ebay for some circle templates and should have one ordered soon. I also saw Monica use one on her build so really want to get one now!
                      Thanks Moni, I saw your post and it was very helpful!
                      Here is the latest build update
                      The camo scheme was painted on with Tamiya Red Brown over the Dark Yellow. I painted it the way I would have done Camouflage on my face when we go out on exercise, kind of like how branches look or how shadows go over an object.
                      Some light weathering was done on some of the edges with black showing some chipping too - very light though.
                      The tools were done up as well, I still have to matt coat some of the tools as I have painted their handles a wooden colour which is done by first painting flat earth and then clear orange.
                      The Camo pattern shows up much lighter in the photos than in real life for some reason.
                      Well I still have 4 spare wheels to do, and then some weathering with Vallejo washes and Tamiya Weathering Master and also Decals.
                      Yeah as mentioned previously the camo pattern is much lighter in the photos, but is very distinct in real
                      I hope you all liked the update. All comments welcome
                      • Rbaker
                        • Jan 2016
                        • 245
                        • Richard
                        • Lye
                        John does one in the Shop
                        I have this and it is great and simple to use
                          That's not exactly what we're talking about Richard, although it's a very useful tool.
                          This is what I use - the smaller holes are good for aircraft wheels
                          • monica
                            • Oct 2013
                            • 15169
                            that dose look real nice,Bob,even if the red/brown is a bit lite,its a great camo pattern,real like it,very well done,
                              It's progressing very nicely. Red brown complements the dark yellow.
                              Drove out to The shop in Onnomba FRI, felt obliged to purchase.
                              Brought Tamiya Panther D.
