Im surprised this newish kit has fit issues. The older Airfix 1/48 kit I built a few years ago went together very well.
					Joe's 1/72 Lightning F2A Airfix 1/72
I bashed and sanded and filed and filled. With not a little cursing, I've got the fuselage buttoned up, the nose ring flush and the belly inserts sorted.
[ATTACH]285427[/ATTACH]
[ATTACH]285428[/ATTACH]
Next mission will be the cockpit IP coaming. Dry fitting shows a large gap and it doesn't sit flush with the cockpit sides. Careful dry fitting of the canopy will be required to ensure no further issues.
The wings will require some packing at the roots. One wing wants to droop and the other won't sit flush with the fuselage side.
Apart from those items it looks a good or so far!Attached FilesComment
Cheers Ian. The IP coaming fits okay after testing with the canopy. It seems to sit atop the IP panel rather than aside it.
I've since installed the air brake panels and the gun nose gun panels. The air brakes required a very small thin base (I used tape) to elevate them flush with the fuselage. Wings next.Comment
Keeping the ball rolling slowly... No further build issues thus far, I'm keeping out of trouble.
[ATTACH]286246[/ATTACH]
[ATTACH]286247[/ATTACH]
Landing gear components sprayed aluminium. I'm going to have to replace the long nose probe. Will look at some thin brass tube or something of that nature.
[ATTACH]286248[/ATTACH]Comment
Not much to add, waiting for brass tubing to replace the pitot. Wheels-up landing gear doors are temporarily tacked on ready for priming and painting, to protect the aluminium finish in the wheel wells.
[ATTACH]286387[/ATTACH]Attached FilesComment
Attempt at 'black basing', very thin matt black sprayed over the primer. Also replaced the pitot with brass tube.
[ATTACH]287015[/ATTACH]Attached FilesComment
Humbrol Metalcote Polished Aluminium applied over three light coats, there is some variation but not apparent in photos. After polishing the nose ring I noticed a weird defect (caused by me without doubt) and so I am back to a light repair. AFter this is dealt with I'll need to spray some more polished aluminium around the front of the aircraft, then mask off for the blue spine/tail and black canopy/nose area.
[ATTACH]288148[/ATTACH]
Public service announcement: anyone building this scheme, note that Airfix has an error in depicting the black nose area. Photos show the black extends to the end of the polished intake ring in a curve, not a squared off per the instructions.
[ATTACH]288149[/ATTACH]
[ATTACH]288150[/ATTACH]Comment
