Fernando N's Ace British Light Tank Mark.VI C
  • Fernando N
    • 2448
    Hi everyone,
    With just more than a month in this GB I thought I add this one to the line-up:
    Although not so many parts, they need a lot of clean-up and I probably will replace the barrels with some brass rod:
    Instructions, tracks and decals:
    Four marking options, I’ll be building the Maltese variant as it caught my eye in the first place:tongue-out3::
    Started on the hull and cleaning the first bits of the running gear which took at fair share of time:
    The side of the box also states: ’’This box contains a plastic kit made under short run technology.’’ nothing lied there but with some patience and TLC it will end up fine, I hope...:rolling:
    Thanks for looking in.
    Fernando
  • stillp
    • 8309
    • Pete
    • Rugby
    Interesting - another manufacturer I hadn't heard of.
    • Steve Jones
      • 6615
      A 1 72 tankette!!! Rather you than me mate :smiling2:
      I have been very interested in this camo scheme and seen it on a few completed models. No idea how to do it. I assume it will be with the brush.??? Will you be having a go yourself?
      Good luck with the build
      • Fernando N
        • 2448
        Evening all, sorry for the late update, progress continued at a steady pace but forgot to share it with you all….
        Pete, they make lots of interesting subjects and as far as I know only in 1/72 and hopefully others are better fitting….:rolling:
        Steve, thanks:thumb2: and this little critter reminds me of a CVR(T) but maybe I made the barrels too long, more on that later.
        For the camo it’ll be a combo of AB and brush work, done before on a 1/76 sd.kfz.9 with good result.:smiling:
        Been quite busy modifying or replacing parts with scratch built ones as the kits offerings are sometimes pretty simplified….
        First replaced the mudguards, only after cleaning I realised that their shape was off to the box-art and corresponding photos of this tank on the net:
ID:	1088226Click image for larger version
ID:	1088227Click image for larger version
        Then came the turret, after careful cleaning it up the sides were quite barren:
        Made a bunch of rivets for it, although a bit large 0.6mm is the smallest size I could punch out:
        Also made new barrels from 0.4 and 0.8mm brass tube with styrene cones and beefed up some of the hinge details :
ID:	1088231Click image for larger version
ID:	1088232Click image for larger version
        The smoke dischargers were moulded quite badly, so making new ones was quicker than cleaning them up:
        Last bits were installed on the hull and turret, added 0.3mm brass wire for the antenna and drivers mirror instead of the kits advised 0.8mm???
        So ready for paint here:
        Yesterday I gave it a coat of Vallejo Dark Yellow primer as a start to see if it looked the part (found a painting instruction of a 1/35 Vulcan models variant telling to use Desert Yellow and Nato Green for the scheme):
        As the Dark Yellow was a bit too dark for my taste, I mixed up VJ 71.025 Dark Yellow and 71.001 White in a 8/3 ratio for the look I was after:
        With more than a day old the paint is still tacky, doesn’t help with this weekend being all rain here and humidity high in the house.:rolling:
        I’ll give it a couple more days to dry and then it’s on to the ‘’Stone Wall camo’’.
        Fernando
        ps. Not intended to make an accurate version here, just my take on the matter….:tongue-out3:
          Fernando,
          the 1/35 version was small enough for me!
          I seem to remember Airfix did a 1/76 Mark VI many years ago - a rebox of JB models original. With the Vulcan model, not bad coverage for such a small tank
          • Si Benson
            • 3572
            Top work mate,
            You’ve really knocked that into something decent looking. Some really nice additions :thumb2:
              S-Model have one in 1/72 — well, two, actually, because with S-Model you normally get two to a box I found it to be a very nice model, quick-assembly like wargaming-oriented kits but with the kind of detail and finesse I’d expect of a modellers’ kit.
                Wow - superb detailing on the little blighter.
                • Mini Me
                  • Jun 2018
                  • 10711
                  Hi Fernando, just like working in 1/87 scale ! lol:smiling5:. Terrific progress and much scratchery is a
                  Huge improvement over the kit parts. Rick H.
                    • 16304
                    Hi Fernando
                    Well Sir you have made a cracking job of this. Definitely an improvement on the kit.
                      You've put some great work into this Fernando :smiling2:.
                      • Steve Jones
                        • 6615
                        Absolutely gobsmaked!! What a stunning little build. You have excelled yourself on this one mate. Looking forward to seeing how the the paint job turns out.
                        • Fernando N
                          • 2448
                          Evening everyone,
                          Dave, Si, Peter, Rick, Jim, Ralph and Steve thanks for the kind comments guys.:thumb2::smiling:
                          Not so much photo’s in this update but the work involved almost took up the same amount of hours.:smiling5:
                          The instructions were next to useless in painting, telling one to look at the box-art for the Malta version and not even calling out the colours needed….
                          Luckily I found a Polish webstore who has a hi-res copy of the Vulcan models painting instructions, making painting a lot easier.:thumb2:
                          As I intended to extend the camo scheme to the running gear too, I still had to scour the net for some usable pics and add a guess here and there to complete the pattern.:rolling:
                          Hand-painted A.MIG-084 NATO Green for the pattern with a 5/0 brush, Revell and Humbrol enamels for the remaining details and the search and head lights were done with a chrome pen (unseen here):
                          It’s under a coat of gloss now, in preparation for the decals (all two of them) and weathering.
                          Fernando
                          • Steve Jones
                            • 6615
                            It just keeps getting better mate. Fantastic base coat. Really looking forward to seeing where this one goes. Great stuff :thumb2::thumb2::thumb2::thumb2:
                            • Graeme C.
                              • 1628
                              • Graeme
                              • UK
                              Nice work Fernando, the stone wall camo looks great.:thumb2:
