BarryW’s Zoukei Mura 1/32 Ta152 H-0
    • 22983
    #16
    Looking NICE Barry
    • stillp
      • 8309
      • Pete
      • Rugby
      #17
      Looks good Barry.
      • Mickc1440
        • 4859
        #18
        That's a great start on the model Barry. Really like those instructions.
        • AlanG
          • 6296
          #19
          Looks excellent Barry
          • BarryW
            • Jul 2011
            • 6142
            #20
            More progress
            The sides are joined. I have left some sections free of cement to be manipulated into position as I join the wings etc.
            [ATTACH]320770[/ATTACH]
            The long, long wingspan
            [ATTACH]320771[/ATTACH]
            I have to cuts some parts away inside the fuselage which will help attach the engine. I am not sure how that could possibly work if I had not done so.
            [ATTACH]320772[/ATTACH]
              • 16302
              Hi Barry
              I had not heard of this manufacturer until I saw their stand at a show. Very impressive looking kit. I was going to say that the seat would look great with careful painting and yesterdays photo shows I was right - you have done that beautifully. Good luck with those wings - they're huge.
              • AlanG
                • 6296
                #22
                Have to admit i've never really watched a ZM build before and i have to say that i am mightily impressed at the detail the kit has.
                • rtfoe
                  • 9227
                  • Richard
                  • Shah Alam, Malaysia
                  #23
                  Lovely office Peter and good foresight in adjusting parts to fit on an otherwise flawless kit. Most ZM kits I've seen are basically in friends stashes. Cost wise is keeping me from getting one. I've only seen one ZM UHU kit built by a friend and that was already huge.
                  I believe ZM has looked into how to manage and strengthen the fit of the long wing.
                  • BarryW
                    • Jul 2011
                    • 6142
                    #24
                    I have been doing more work on the fuselage.
                    The bottom panel fixed into place well. Only a little filler will be needed.
                    [ATTACH]320940[/ATTACH]
                    More work on the wing.
                    Some filler needed but overall a good fit.
                    [ATTACH]320941[/ATTACH]
                    Working on the on the undercarriage. I used a sharpie to help line up the location tab on the hub with the tyre.
                    [ATTACH]320939[/ATTACH]
                    • BarryW
                      • Jul 2011
                      • 6142
                      #25
                      I am progressing work on the airframe and decided to test fit the undercarriage legs.
                      As you can see from the instructions they twist fit into the locations. But the tolerances and very tight and I had to sand a little to ease the fit. Once in place they fitted perfectly and I was loath to remove them so I cemented them into place a lot earlier than intended. Hopefully they are strong enough to survive...
                      [ATTACH]320971[/ATTACH]
                      [ATTACH]320972[/ATTACH]
                        I'll join you mate with my 1/48 ZM Ta 152 once I finish off my viper....
                        btw, good job this is looking great
                        Cheers, John
                        • BarryW
                          • Jul 2011
                          • 6142
                          #27
                          Some more pics.
                          First the wing tip light. These are so small they are impossible to pick up with fingers, a pick-up stick can pick it up but getting it into position and into the location hole is nigh on impossible, tweezers are useless given shape and size. You can just make out the part as that dot near the wing tip. Because of the challenges I decided try to cement the part in now and then paint/gloss it at the end. But no, moments after the pics was taken it disappeared into the ether, not unexpected. Consequently I filled the hole but not completely level and smooth at the top. As part of the final touches I will drop a little paint into the hole and the apply some clear material I have that will bead out slightly giving the desired effect.
                          [ATTACH]321281[/ATTACH]
                          The tail in cemented I to place but I need to fill a small step
                          [ATTACH]321283[/ATTACH]
                          A fair bit of work left on that to do.
                          While filler is drying I airbrushed black MRP primer
                          [ATTACH]321284[/ATTACH]
                          Also on the wing. There are a few minor imperfections shown up that I will fix with some sanding.
                          [ATTACH]321282[/ATTACH]
                          I will aim to finish off the fuselage join, sand the wing and then fix the wing to fuselage. More over the next couple of days.
                          • colin m
                            • 9066
                            • Colin
                            • Stafford, UK
                            #28
                            Again, a great build log Barry and an impressive build.
                            • BarryW
                              • Jul 2011
                              • 6142
                              #29
                              I have fitted the wing to the fuselage and it is a perfect fit, it could not be better. A lot of reviews suggest otherwise but I think the engineering, in many ways great, does provide scope for problems to occur and I think the secret is to plan ahead and dry fit every stage.
                              [ATTACH]321478[/ATTACH]
                              [ATTACH]321479[/ATTACH]
                              As you can see I am getting on with some painting of sub-assemblies. I will need to apply a small amount of Mr Dissolved Putty in places finishing off with some ‘liquid sanding’ with i.p.a.
                              I am planning to fit the cowls around the engine before fitting that to the fuselage. As I will not be displaying the engine a snug fit is the priority and I think that will reduce the potential for problems.
                              • AlanG
                                • 6296
                                #30
                                I wish i had your talent Barry. Class build again
