Windy's Matchbox/Revell GB entry - Char B1 Bis and FT 17.
  • Windy
    • May 2018
    • 379
    • Alex
    • Dorset
    Hi all. The Dragon Churchill Mk IV has temporarily gone onto the shelf of doom while I work out what to do with the disastrous paint job, so here are my entries for the Matchbox GB. As promised I've got the Char B1 Bis and FT 17 which I've wanted to build for years.
    First off the box:
    Then the sprue shot:
    And kit history from Scalemates:
    Nice, I always liked these two (and in fact, built at least two of each over the years ) so it’ll be interesting to see what you make of them. I see Revell now mould them in grey, not green like they used to.
    • Windy
      • May 2018
      • 379
      • Alex
      • Dorset
      Hi all. Quick update. FT 17 built and ready for undercoating. It's a very simple little build and went together with no dramas. Char B next. The walls aren't glued to the base yet as I might widen the roadway a bit.
        • 18286
        Before things get to mixed up please can you make a separate thread for the priest . Forum GB's rule one subject per thread. Unless the GB Is a diorama GB.
        • Windy
          • May 2018
          • 379
          • Alex
          • Dorset
          Roger. Wait out.
          • Windy
            • May 2018
            • 379
            • Alex
            • Dorset
            Thread duly amended!
            • yak face
              • Jun 2009
              • 14076
              • Tony
              Brilliant choice alex , these look excellent and if i recall theyre really small as tanks go . The base was a good one too , with the fallen shutters and the arch . Cheers tony
              • Windy
                • May 2018
                • 379
                • Alex
                • Dorset
                Thanks mate, it's a nice little kit. And yes, they were tiny. They had a two man crew and were about 16 ft long and weighed 6.5 tonnes. The model is just over two and a half inches, including the skid at the rear.
                  This gives a good impression of its size:
                  • Windy
                    • May 2018
                    • 379
                    • Alex
                    • Dorset
                    Char B done. It needed a lot more cleaning up than the Renault, as did the figures, but it went together with no issues. I was going to replace the antenna with a bit of wire but then I had a look at some original photos. The bloody things were like tree trunks!
                    I might get them undercoated tonight, but unfortunately I'm working all day tomorrow so I'll have to wait until tomorrow night to make a start on painting.
                    Here's an original picture showing the size of the radio antenna!
Name:	b1 111 dunkerque 01.jpg
                    • yak face
                      • Jun 2009
                      • 14076
                      • Tony
                      Jeez Alex that’s a big aerial , It’s more like a flagpole ! if you compare it to the blokes finger in the photo it must be about 1-2 inch in diameter! For once the kit makers got it spot on , although like yourself if I hadn’t seen the photo my first instinct would be to replace the kit aerial with something a lot thinner
                      • Mini Me
                        • Jun 2018
                        • 10711
                        More like a "Mast" than an aerial:smiling5: Rick H.
                          Older tank antennas are often much thicker than people think, and frequently tapered rather than with parallel sides.
                          It will break off anyway (I say from experience with this kit ).
                          They could put a sail on it to make the tank go faster in a suitable wind. It kind of needed that, with its top speed of 28 km/h on a good, flat road.
                          Oh, and:—
                          • Windy
                            • May 2018
                            • 379
                            • Alex
                            • Dorset
                            Bit of progress at last. Wretched things like work keep getting in the way! Figures are done, though they need a coat of matt varnish yet, and I've made a start on the B1. I decided I couldn't live with the kit antenna after all so I replaced it with a bit of wire. I also added a couple of hooks for the tow chain to the rear plate.
                            • Neil Merryweather
                              • Dec 2018
                              • 5274
                              • London
                              very nice Alex
