Tamiya 1/35 Sherman M4A3E8 Complete
    Ok, chaps, here it is. The Tamiya new tool M4A3E8 "Easy Eight."
    As per my past experiences thus far with Tamiya kits, this one went together with no problems. Everything fit and the instructions were clear. One thing that stands out to me on this kit, is the way the upper hull attaches to the lower. I pointed it out on an earlier installment, but in short, a tab on the front of the upper front hull slides underneath the front transmission/differential casting, while the rear attaches via a pin in the upper hull fitting into a poly sleeve (similar to the poly sleeves that Tamiya uses for attaching wheels) in the lower hull. No glue necessary. Once together, the front has no gap whatsoever. It looks like it is cemented in place. The benefit of this, for me, is that the hull can be painted and weathered, then assembled. Then once it is done it can be separated so the tracks can be installed, then reassembled. To me, this is a prime example of the engineering that makes a kit great.
    The tracks, although of the dreaded "rubberband" style. are molded very nicely with very good detail.
    The weld seams and cast texture are very well done, as well as the cast numbers/letters.
    The kit supplied, styrene barrel is nicely done and the very faint mold line is easily removed without distorting the shape. The muzzle brake is multi-piece, but also goes together well and looks great once cleaned up.
    Now, I will discuss places where I think the kit could be a little better. Keep in mind, these are my opinions and these items don't really detract from the finished product.
    First, and probably my biggest complaint about this kit, are the hatch grab handles. The handles on the crew hatches are all of the solid, molded on type. It doesn't seem to me that it would be that hard to leave them off, and make the handles a separate piece. It is not really that hard to cut the molded on handles off and make some from thin gauge wire, but given Tamiya's abilities, it would be a nice change. The same goes for machine gun barrels. Hollowed out muzzles would be nice, although it is not too difficult to bore them out with a pin vice.
    For this build, I tried a few new products and techniques. I tried Archer dry transfers for the first time to do the unit markings. I tried some different weathering techniques, most notably the application of pigments. I used pigments for applying thin mud to the lower hull and running gear, as well as the tracks. I was especially pleased with the results on the tracks.
    I also put a small bit of stowage on the vehicle. A couple of fuel cans (kit supplied), and some crew items (packs and duffel bag). I could have made the colors on the packs and duffel bag a bit more different than the vehicle, but in hindsight, it is probably OK as is since it keeps them from standing out too much. Kind of blends in with the vehicle.
    So, anyway, here is the finished product. It represents a 6th Armored Division vehicle in April, 1945 in support of First Battalion, 417th Infantry Regiment, 76th Infantry Division in Germany as they moved closer to the Czech border. My grandfather was in Co C, 417th, during his wartime service.
    I like this, nice weathering going on and the decals look the business.
    scott
      Excellent work Brett - really great worn look, nice bit of chipping and dust / dirt effects!
      it gives me a kick to get mine completed
        Very nicely done Brett.
        • peterairfix
          • Jul 2012
          • 11083
          Nice one I like .
          And that reminds me i still got one to finish
          • Snowman
            • Oct 2014
            • 2098
            Great build!! B|
            • monica
              • Oct 2013
              • 15169
              looks great Brett,well done with the chipping and weathering,like the dirty look,and so nice to see that your
              not scared to dirty up the decals,nicely done,
                • 22788
                I like that a lot
                • Razzie43
                  • Oct 2015
                  • 397
                  Hi Brett,great looking Tank u have there....
                  how big is your collection for the moment?(only usa tanks WWII)
                    Thanks everyone.
                    Razzie43, my US tank collection amounts to two completed and one waiting to be built. I have the Monogram Sherman "Screamin' Mimi," and this M4A3E8 that I just completed. The one I have waiting to be built is the Academy M4A3 with T-34 rocket launcher. And, as soon as it comes out, I will be getting the new tool Tamiya M-10 tank destroyer.
                      great build, a sherman is on my list now, you`ve inspired me. well done.
                      • Razzie43
                        • Oct 2015
                        • 397
                        Hey Brett,i just wanna say that your photobucket is visible for every body.
                        Here are a few of onaway's Public albums
                        Agape models Naked build (2)
                        Archive Junk (0)
                        CT90 Project (40)
                        Familt Pics (77)
                        Floval Flyer Project (38)
                        Grogan History and Research (30)
                        Gun Stuff (7)
                        Hearst Castle Winchester house Vaca 2012 (89)
                        M3 Stuart Honey (21)
                        Marine Raven (0)
                          Thanks Razzie. Fixed that, chop-chop!
