Hello!
It's been a while again. I've recently finished this great Trumpeter's model - BTR 60 PU with interior. When I saw this model kit, immediatly I had this thought of showing the interior via cut-offs in the upper hull. Finally I've picked this one to do and had a chance to do this project. In the meantime I've decided to put some lights inside powered by a battery placed in engine bay (the kit doesn't provide any details in this section.
The kit itself was nicely moulded and detailed. The only problem I had, when it came to join together lower and upper hulls. Dry fitting was ok, but then when everything was finished, big gaps appeared in front.. Managed to fill them and finish the model. When it comes to interior colour, it's not 100% accurate for this exact vehicle. I've done some research and appeared, that there was pretty much everything from white, thru green and even blue. I've painted the instruments in classic russian cold war interior colour greelue (green+blue)
Enjoy and don't be scared to comment!
On some pictures looks like some wheels are not flat on the ground, that's due to my vinyl background, which is quite stiff and model isn't heavy enough to make it flat.. :/
Thanks for your attention, Will be back soon!
Bart.
Bart.
