SimonT Tribute Build – Scratch built Interior of a Stug III Ausf D
  • Steve Jones
    • 6615
    Hi Everyone
    This is my tribute build to Mr T. Unfortunately, it cannot go into the GB as it is over 50% compete. So, look at this and Rick's Zis Fuel Truck as the appetiser before the main event at the beginning of November. :thumb2:
    Simon helped me out on all my builds from either answering a question or doing a full build together. There are signs of his influences in all my builds and I would like to show you those in my finished scratch build.
    Now, no build would be the same without a bit of pewter!:smiling2: Simon introduced me to pewter when I started making my own rivets. He then explained how I could use it for many other applications. Here for example is a support strap on the inside of the Stug.
    On the left-hand side of this next photo you will notice a grab handle. Mr T showed me how to make the flat bases of the handle by squeezing the wire in a pair of flat nosed pliers. Probably the best tool Simon got me to buy.
    We had some fun when Simon introduced me to the world of Compass Cutters.
    My first project that I used them on was building a limber for the B4 Russian Howitzer. I said the compass cutter made my fingers very sore. His reply was “Oh yes, we must suffer for our art:smiling2: I have had so many blisters from compass cutting” he said.:smiling5:
    One skill Simon taught me was the art of building up layers to create shapes. Here is an example of Simon’s own work showing this principle.
ID:	1134487Click image for larger version
ID:	1134488Click image for larger version
ID:	1134489Click image for larger version
    I then applied the same principles on the gear brake system and here, on the transmission box.
ID:	1134472Click image for larger version
    In the early days I did a few builds using PE and always wondered what the small round dents in the PE parts were for.
    Then one day Simon wrote on my blog in his own unique style that I needed to add rivets to all the indentations. Now bearing in mind this was on an artillery piece shield with well over 100 rivets I was not too impressed.:smiling5: However, as you know, if Simon says then it had to be done. This was where my love of all things rivety began. He spoke of his Whippet build which had well over a thousand rivets on it. I thought this was staggering but it was not long before I would be doing the same on my models. He advised me to invest in a punch and die set. When it arrived, he was kind enough to make a holder and base for it from his 3D printer. A true gentleman.
    No matter how small the parts, Simon installed the importance in me of detailing. He said it was important to generate the impression of accurate work even if it is not exactly historically correct.
    The most poignant part of this build was the ammo box.
ID:	1134479Click image for larger version
ID:	1134476Click image for larger version
    There would be times when both Simon and I had not come across a certain problem before and we would talk about different solutions and try them out. This was one such occasion. Sadly, Simon never got to see the result.
    In all my builds there is a Mr T influence. He taught me so much and helped me in so many ways from teaching skills, researching and buying tools. Above all he was a true friend with infinite patience and generosity. We will all miss him greatly, but I know his memory will carry on in all my future builds.
ID:	1134474Click image for larger version
ID:	1134475Click image for larger version
ID:	1134484Click image for larger version
ID:	1134485Click image for larger version
    I am so looking forward to Simon's Tribute GB which is due to kick off in November. It will be great to see all your builds and hear about your tales and experiences that you had with Simon.
    I wish you all the best and happy modelling
    Steve Jones
  • Neil Merryweather
    • Dec 2018
    • 5354
    • London
    wow. just WOW!
    • BattleshipBob
      • 6884
      • Bob
      • Cardiff
      Cracking Steve and a stunning tribute to you both. Great team work
      Oh forgot its also a StuG :tongue-out3::thumb2:
      • Lee Drennen
        • 7738
        Steve. Front row for this one for sure. I will screen JR for any Flammables before for he is seated. This is what happens when two Master Modelers build together amazing work
          • 16311
          Hi Steve
          There could be no better tribute to the Scratch Master than this. You're been a great pupil, the results are superb.
            • 19134
            This is a truly fitting tribute. Great modelling allied with a keen observation of detail. That is the core of Simon’s approach, and one which you are employing to excellent effect here.
            • prichrd1
              • 694
              • Conwy
              Absolutely amazing, a real tribute to a master of scratchduggery.:thumb2::thumb2:
              Paul.
              :smiling2:
                Epic work Steve.
                Simon mentioned his layering method to me but I haven't gotten around to trying it yet. Looking at those results, especially the wheel, I can see just how useful it is!
                  Absolutely fantastic modelling Steve :smiling3:.
                  • Si Benson
                    • 3572
                    Considerably impressed old chap....that was a lovely piece to read and I think those of us that had the pleasure to converse with MrT will totally appreciate your connection.
                    Excellent work on the StuG as well mate....looking the mutts nuts :thumb2:
                    • adt70hk
                      • Sep 2019
                      • 10554
                      Quite simply the best scratch interior I have personally ever seen!!!
                      ATB
                      • Steve Jones
                        • 6615
                        That says it all Neil. Many thanks my friend
                        You had a lot to do with it as well Bob. I would have been lost without all your reference material and help. Many thanks mate.
                        That's kind of you to say Lee but more like one magician and his apprentice:smiling3:
                        That means a lot Jim. Much appreciated sir:thumb2:
                        Very true indeed Tim. Simon's models oozed detail. They are great to look back on.
                        Kind of you to say Paul. Indeed he was the master
                        Its such a simple technique Andy but so very effective. It will be a while before I get up to his standard. Those wheels of his were awesome.
                        Many thanks Ralph. Glad you liked it
                        That's kind of you to say old bean. We all have stories to tell about Simon. Looking forward to hearing some of yours Si
                        I am humbled by your comment Andrew. We all have Mr T to thank for it.
                          So that's what you've been up to! Just astonishing work Steve, and fitting tribute to Simon's input.
                          • BattleshipBob
                            • 6884
                            • Bob
                            • Cardiff
                            Totally my pleasure Steve, you have been very kind to me, not forgotten my friend!!
                              Looking at those photos Steve they say it all. You learned so much and put it into practice His teaching will live on in your work with outdoubht.
                              John.
