Amusing Hobby Centurion Mk 5 AVRE
  • wasdale32
    • 1118
    • Mark
    Picked up in the closing down sale of our local model shop after the sad passing of the owner.
    This tank represents one of the Mk 5 Centurion AVREs that served in the first Gulf War.
    Built pretty much out of the box - the kit is based on the Amusing Hobby Mk5 gun tank and the hull and running gear are very similar to offerings from AFV Club.
    The main accuracy issue in the kit is usually stated to be the road wheels which lack the reinforcing rings seen on the real vehicle ( a moulding restriction ) but as the running gear is largely
    hidden by the side skirts and armour packs I decided to use the kit wheels. The kit also lacks clear parts for the optics which would have been nice to have
    The tracks are individual link "workable" type and do clip together fairly positively - I assembled them into "link & length" segments for ease of handling and painted before fitting.
    I mostly followed the build instruction sequence but didn't fit the hull top and skirts until I'd painted the running gear which was then masked when priming and spraying the upper hull.
    The kit itself was a clean build with all parts crisply moulded and little tidying up required.
    The paint colour was mixed from a variety of Mr Color acrylics and may not be entirely accurate but I hope does look reasonably close.
    The figures are from a 3D printable set supposed to be Challenger crew but have had some head swapping and a bit of minor surgery.
    Awaiting a suitable base.
Name:	IMGP3991 (Large).JPG
ID:	1224356Click image for larger version
Name:	IMGP3992 (Large).JPG
ID:	1224357Click image for larger version
Name:	IMGP3993 (Large).JPG
ID:	1224358Click image for larger version
Name:	IMGP3994 (Large).JPG
ID:	1224359Click image for larger version
Name:	IMGP3995 (Large).JPG
ID:	1224360Click image for larger version
Name:	IMGP3996 (Large).JPG
ID:	1224361Click image for larger version
Name:	IMGP3997 (Large).JPG
ID:	1224362Click image for larger version
Name:	IMGP3998 (Large).JPG
ID:	1224363Click image for larger version
Name:	IMGP3999 (Large).JPG
    • 16169
    That built up very well indeed. Crew look to fit nicely. Definitely one to be proud of.
    • A_J_Rimmer
      • May 2024
      • 801
      • Arnold
      • North Wales
      That's an absolutely fabulous build! :thumb2: :thumb2: :thumb2:
      I had no idea that Centurions will still in service by that point - awesome!
      Arnold Judas Rimmer BSc SSc
      ''Happiness is a Triple Fried Egg Sandwich with Chilli Sauce and Chutney''
      • wasdale32
        • 1118
        • Mark
        Apparently the troops nicknamed them "The Antiques Road Show"
        • spanner570
          • 15599
          Cracking build Mark and very nicely presented too. :thumb2:
          Well done.
          Presentation of a finished model is something a fair few people ignore and can ruin what should be a nice end to a lot of hard work....Not so here.
          Ron
          • scottie3158
            • 14578
            • Holbeach
            That's a cracking result.
              Think this deserves
              Great work Mark .
              Congratulations .
