RAF Quad Bikes and Trailers : airfix 1/48
    Just a lovely kit. Great to build and such a different type to build.
    Lots going on. all went just as you would hope.
    Just a little filler but OK forgiven.
    An addition to Afghanistan collection. Surprised I have stayed with it
    But it is compelling.
    Used Mr Cement S. Filler Mr Surfacer 500 and after priming a bit of Vallejo Plastic Filler.
    Vallejo primer, Vallejo top coats, Lifecolor for the effects. They do some very nice dust sand colours.
    Primer and top coat Iwata HPBS .35 needle 18psi. Effects Iwata HPBH .2 needle 8PSI.
    [ATTACH]115584.IPB[/ATTACH]
    [ATTACH]115585.IPB[/ATTACH]
    [ATTACH]115586.IPB[/ATTACH]
    [ATTACH]115587.IPB[/ATTACH]
    [ATTACH]115588.IPB[/ATTACH]
    [ATTACH]115589.IPB[/ATTACH]
    [ATTACH]115590.IPB[/ATTACH]
    [ATTACH]115591.IPB[/ATTACH]
    [ATTACH]115592.IPB[/ATTACH]
    [ATTACH]115593.IPB[/ATTACH]
    [ATTACH]115594.IPB[/ATTACH]
    [ATTACH]115595.IPB[/ATTACH]
    Lovely job Laurie. I like a diorama that you have to study to see everything and it takes you time to absorb it all. Lovely detail and some great weathering.
    • monica
      • Oct 2013
      • 15169
      do like it Laurie,very nice little outing for the lads,very nice work with all the,
      bikes and other,the figures with the camo is never easy,well done,
      • takeslousyphotos
        • Apr 2013
        • 3900
        Superb job Laurie ......... There's a lot going on in there. Very well put together matey......... I like it a lot.
        • Robert1968
          • Mar 2015
          • 3596
          Very nice Laurie that looks perfect and they fit in the dio so well, as others have said lots going on and lots of detail in these quads, like your weathering too
          Grand job really it is I like this a lot
          Regards
          Robert
            The other day, I had one of those kits on my hands Laurie!!!
            Looking your work and how lovely they has turned, I think was a mistake leave it on the shop shelves again
            Nice build!
            • flyjoe180
              • Jan 2012
              • 12943
              • Joe
              • Earth
              Absolutely great job Laurie. The bikes and figures all look A1. The scene with the Merlin in very nicely done.
                • 22954
                Awesome work Laurie they may be small but look great
                  Great work, I think you have put this together well. I like the subtle paint effects that reflect the environment well. Nice build and nice dio work.
                  My only negative point would be the rocks, they kind of look like they need to be buried a bit and blended in more.
                    Very nice, they all look good
                    • Gern
                      • 9301
                      Very, very nice Laurie. You're putting together an excellent set of themed kits there. Only odd thing to my eye is seeing all the 'desert' stuff on a grass layout. I think it would look much better on a sand base.
                        Superb work laurie. When did you do the chopper?
                        How does the .2 needle work on the iwata? I am thinking of upgrading my Hi-Line HP-CH to that spec, as I only want to use a .2 for fine work and use my eclipse for the majority of painting
                          Thanks for your nice reply Dougie.
                          Quite right about the rocks. As I have finished each of the Afghanistan bits something gets moved.
                          It is a mess at the moment as I have had to move WW11 exhibits over. For the moment I have just thrown pieces together.
                          I also have to move pieces for photography and they never get put back. Must train wife
                          Thanks for your nice reply Dave
                          The grass Dave was laid for WW11 aircraft all now moved over. As mentioned above it has been roughly put together.
                          Not until I know the scope with all the Afghanistan pieces completed will I know the extent I need to prepare..
                          Until then regret I will have to keep that grass mown. Must train wife
                          Al in all the layout will not be a diorama as it will not tell a detailed story. Just a background layout showing the pieces
                          in their working background. It would be most unusual to have 3 helicopters,a Harrier, a Typhoon and 4 armoured type
                          vehicles and quad bikes huddled together. A helicopter will be suspended, I think.
                            My idea as well John. .35 general work..2 for small detail where you get in difficult areas the spray width is smaller. also for effects work. I have found the HPBH works very well. I have tried the Micron but discarded as I found the HPBH much better, for me. First of all I had great problems with Vallejo Air and Lifecolor thro. the .2. But since I have started using Vallejo Flow Improver it works as if by magic. Hardly have an blockages and these are quickly cured with a quick full squirt. Also been air brushing at 8PSI. This is superb as it gives time to build up the depth of paint colour. I do not bother much with washes. Flow improver Val. Model Air 50% thinners and there is a great wash.
                              This is the one John.
