A question?
  • Alan 45
    • Nov 2012
    • 9833
    A question?
    if you bought a tank model and this was included in the features of the kit what would you expect
    Pressed wheels with perforated rubber tires and rims !
    Not knowing which kit it is makes it hard to comment, but if a feature that's listed on the box isn't present then that's false advertising & you're entitled to a refund.
    • Alan 45
      • Nov 2012
      • 9833
      Well I could take it back and use this as a reason to get my Money back but it's a nice kit so I won't
      This would apply to any kit really if you read that on the side of a box you would expect to get what it says
      • eddiesolo
        • Jul 2013
        • 11193
        I take it is supposed to have separate wheels and rubber track tyres?
        • Alan 45
          • Nov 2012
          • 9833
          Your spot on mate , the statement the special addition of Academy's T34/85 and that is stated on the box but the wheels are solid plastic , very detailed mind but still if you see the word rubber on the box your expecting to get rubber , there's no mention of rubber in the instructions
          Great kit though lots of parts detailed plastic tracks with seperate links at the bends , pe bed spring armour and a real looking cast turret you don't get that on a lot of T34 kits
            I know that kit & it's slightly misleading to be fair! But personally the thought of separate rubber rims doesn't work for me - they can be a PITA to glue & paint!
            btw the cast texture on the turret is rather overdone - compare it to a DML kit & you'll see what I mean! And good luck with the ejection pin marks on the tracks - too much filling & sanding for me!
            • Alan 45
              • Nov 2012
              • 9833
              I thought the rubber trims would be good , the injection pin marks are very shallow and on the inside of the track so the wheels will cover that
              You make a good point about the turret but that's to my advantage, with what I have in mind , I won't be giving it a dark wash I will highlight the top with a lighter colour this will hide the depth of the turret surface , it will look even better if I do a winter version
