Tiger I (Tac Number 100) Initial Production ,Rye Field Model - No. RM-5075 Exhausts
  • slupanter
    • Jun 2010
    • 554
    Hi all,
    Please could someone help me out
    Does anyone have the Rye Field Model's No. RM-5075
    I am looking for the measurements the extended exhaust tips highlighted in the picture below:
    Sorry Alexander I can't help, but bumping this up the list might find someone with the answer.
    Have you lost the parts ?
    • slupanter
      • Jun 2010
      • 554
      Hi John, I am building the Dragon 100 and I want to extend the exhaust flash shields as on the real tank.
      Thank you for the bump
        When I measure them in the drawing, the exhaust on the tank is 48.51 units long (says Photoshop), while the extension is 24.19 units. So, measure up the length of the exhaust on your Dragon kit, multiply by 24.19 and divide by 48.51 to get an approximate height of the part you need to add. They also seem to be 7/8ths the diameter of the lower exhausts (the lower ones measure as 8 wide, the upper as 7).
        [ATTACH]459113[/ATTACH]
          [ATTACH=CONFIG]n[/ATTACH]
          Thank you Jakko .I knew some one would hopefully have the answer !
          • Gary MacKenzie
            SMF Supporter
            • 1059
            • Gary
            • Forres , Moray , Scotland
            The Tiger's HL210 engine had two exhaust pipes, and they exited the hull through holes in the lower...
            states 500mm extension on Tiger 100
