Rubber tank track - help please
  • mossiepilot
    • Jul 2011
    • 2272
    This has probabily been asked before but I can't find a thread that covers it.
    I'm a newby to armour and have got a Sherman callope, it looked an interesting build. The problem I got is the rubber band tracks, the instructions say "seal with heat" and I can sorta see that heating the joining pin with form a rivet and hold the track together but there must be a better way and I'm worried that with my thumb fingers I'll melt the track too.
    If there is a tutorial can someone please point me to it.
    Any help and advice gratefully received.
    Tony.
    I don't know if it can be of help... Only I build one tank but...
    I joined the pieces of the track one to one with glue (not Loctite), it was a glue that melts a bit the plastic (weld). His exit is of the thickness of a pin and allows to dose very well. The time of dried is so rapid as the loctite and allows to mold a bit before drying. This way it's possible to give form together with the wheels.
    I wait help a bit, I'm sorry, it is the only experience that I have...
    Regards
    Polux
      I just heated the tip of a screwdriver up over the stove. Worked a treat. Hold it close to the track at first and then a quick press down on the little nub thingy and it was fine.
      • mossiepilot
        • Jul 2011
        • 2272
        Thanks for the advice guys, I'll give it a go.
        Tony.
