Flakpanzer IV Ausf G Wirbelwind (Dragon)
  • Panzerwrecker
    • Mar 2022
    • 599
    • Los
    • Wales, UK
    This is my first weekend painting and weathering session of the new year and I'm moving on a project I started around seven years ago! This will be a quick paint and weathering exercise on a kit already fully built and primed. This is one of four Flakpanzer IV variants that Dragon released. Kit 6342 was available in 2011 and labelled an Ausf G 'Early production'. Although as you might expect, the box is crammed full of sprues of which some are also marked Ausf H, the Aufbau moulding is an Ausf G so I would guess you could portray both an early and late Ausf G out of the box. However, zimmerit should be present if representing a post Sept 1943 vehicle. The instructions have you add the front and bow plate bolted additional armour.
    Two early 12th SS field applications, one with just frontal flak gun armour
    One of the first prototypes built on an Auf G hull
    Click image for larger version  Name:	ad_spaag_wirbelwind_p03.jpg Views:	0 Size:	108.3 KB ID:	1248074
    Ausf G hull without zimmerit. Notice the Notek light on the vehicle above and below
    It's been a while, but I don’t recall any issues with construction. I did damage and remove areas of the track guards and I'm pretty sure the brass barrels are aftermarket. I also added a few parts from the spares bin to improve a few areas. Many Ausf G hulls were repaired and re-used to accommodate the Wirbelwind open turret, so it was highly likely that they were at least partly re-painted when construction had completed and before any camo was applied. I plan to ensure the Aufbau paint covering has a much older look than the turret. Dust layers will help in that department too.
    Under construction in 2018
    Although stored in a plastic storage box the first thing I did was to give it a good blast with an empty airbrush to remove any dust buildup. The slight sheen of the rattle can red oxide helped in this respect as any small particles had limited adhesion.
    Tamiya rattle can red oxide primer
    Always wanting to try new techniques and having never tried it, I first pre-shaded using Mr Surfacer 1000 Mahogany (dark brown base) to add depth to shadow areas. The exhaust muffler and spare track links were totally covered with the dark brown base and then the two darkest Lifecolor shades of their rust set was stippled on. Once cured, two fine coats of hairspray were added. Both the exhaust muffler and spare tracks then received a light airbrushed coat of Vallejo Track Primer followed by more hairspray. Tamiya Lacquer LP55 dark yellow was airbrushed as a Dunkelgelb base coat and then slightly modulated to lighten upper areas of the vehicle. Raised details were then brush painted with Vallejo Iraqi sand and buff and care of the hairspray layers, fine chips were made on edges and damaged areas. Another two fine coats of hairspray followed.
  • Panzerwrecker
    • Mar 2022
    • 599
    • Los
    • Wales, UK
    The camo was airbrushed freehand with a finer Iwata needle with the compressor set to around 12psi. I used Tamiya Lacquer LP56 dark green 2 followed by LP57 dark brown 2. Once dried, with the aid of those underlying hairspray layers, high usage and damaged areas, along with the exhaust muffler and spare tracks, were distressed, burnished, and lightly chipped.
    Click image for larger version  Name:	IMG_5999-2.jpg Views:	0 Size:	270.6 KB ID:	1248132
    The tyres were brush painted with Vallejo dark rubber and the pioneer tools and bow machine gun brush painted in their base tones. AK light mud acrylic texture paste was then applied with a brush around the running gear, the sprockets, and the idlers to add some built up mud texture. Being acrylic it can be easily manipulated, removed, and blended into the surface with H2O.
    Click image for larger version  Name:	IMG_6000-2.jpg Views:	0 Size:	278.1 KB ID:	1248133
    Click image for larger version  Name:	IMG_6003.jpg Views:	0 Size:	273.4 KB ID:	1248134
    Click image for larger version  Name:	IMG_6008.jpg Views:	0 Size:	368.3 KB ID:	1248135
    Lightly chipped camo on the engine deck and multiple chipped layers and stippled rust tone effects on the exhaust muffler
    , courtesy of Lifecolor’s excellent acrylic rust set.
    Click image for larger version  Name:	IMG_6005.jpg Views:	0 Size:	333.4 KB ID:	1248136
    AK’s acrylic light mud texture paste added to the lower hull and running gear. Looking crude for now but these effects will be enhanced with both additional airbrushed acrylic dust tones and then with enamel and oil washes in later steps.
    Click image for larger version  Name:	IMG_6009.jpg Views:	0 Size:	356.5 KB ID:	1248137
    Click image for larger version  Name:	IMG_6014.jpg Views:	0 Size:	263.0 KB ID:	1248144
    I'm hopeless at creating my own paint chips by hand. Ive tried and failed miserably, so relying heavily on the hairspray method has allowed me back some control over effecting some types of heavy wear marks on painted surfaces. It also speeds up the process for me. This very same technique can also be adopted onto airbrushed dust layers, but the process of removal, and more importantly where it remains, needs to reflect the reality witnessed on operational AFV's. I'm very slowly getting to grips with how to acheive these effects so this project is very much a work in progress in that regard.
    Once the texture paste had fully cured, two fine misted coats of hairspray were added to the whole model. Two heavily H2O diluted dust toned Tamiya acrylic mixes were then airbrushed over the running gear and lower hull. The lighter of the two dust tones was sprayed from above onto just the horizontal surfaces. These dust layers were then gently agitated to portray the effects of crew movement disturbance on horizontal surfaces. On the outer vertical surfaces the effects were more of scape marks.
    Click image for larger version  Name:	IMG_6020.jpg Views:	0 Size:	296.5 KB ID:	1248138
    Mixing the acrylic dust tones with H2O instead of thinners allows the overlying paint layers to be removed with very little force, so it’s easy to replicate the effect of the dust layers being smudged, scraped and rubbed off around hatches and edges. Other areas where dust deposits would have been continually removed like the contact areas of tyres, sprocket teeth and the contact surfaces of the idler wheel, were also worked on, leaving deposits in place inbetween raised detail.
    Heavily diluting these acrylic dust layers means they are easily disturbed and disrupted with just the slightest sniff of H2O on a damp brush. I found the very slightest contact with a cocktail stick would effortlessly leave fine scratches and marks. In the case of the engine deck brushing over an asparagus fern was all that was required to create some interesting effects.
    Another beneft of these airbrushed dust layers it that it has a harmonising effect of blending in the previous texture paste effects around the running gear.
    Click image for larger version  Name:	IMG_6017-2.jpg Views:	0 Size:	235.7 KB ID:	1248139
    It’s a simple process to airbrush on more dust layers if too much is accidentally removed. Whilst removing the dust layer from the tyre contact surfaces I accidentaly exposed the red oxide primer on the tyre edge on a few wheels. These were so few in number that instead of adding another layer of dust I simply
    touched up the edges with fresh Vallejo dark rubber, which gave an additional highlighted effect.
    Click image for larger version  Name:	IMG_6021-2.jpg Views:	0 Size:	210.2 KB ID:	1248140
    Click image for larger version  Name:	IMG_6032.jpg Views:	0 Size:	264.1 KB ID:	1248143
    Airbrushed base coat, camo layers and dust layers completed. Adding wear and tear marks at different stages of the painting process has built up distinctly different results. I have only applied two tones and two layers of dust coloured paint so the possibilities for using this technique are endless. The running gear and lower hull is now ready for some enamel and oil washes, so I can next move on to applying a slightly reserved application of dust effects to the turret
    Click image for larger version  Name:	IMG_6026.jpg Views:	0 Size:	283.0 KB ID:	1248141
    Click image for larger version  Name:	IMG_6030.jpg Views:	0 Size:	266.4 KB ID:	1248142
    • minitnkr
      • 7785
      • Dayton, OH USA
      Shaping up beautifully.
    • Airborne01
      • Mar 2021
      • 4297
      • Steve
      • Essex
      Loving this already!
    • Steven000
      • Aug 2018
      • 2891
      • Steven
      • Belgium
      Very nice progress los, and lovely paintwork 👍
      • Panzerwrecker
        Panzerwrecker commented
        Editing a comment
        Appreciated Steven
    • rtfoe
      • 9208
      • Richard
      • Shah Alam, Malaysia
      I love your paintwork Los. All is looking really good.
      Putting it in a Dio or as a single display?
      Wabble
      • Panzerwrecker
        Editing a comment
        Thank you Wabble. Undecided as yet, but having two dio projects on the bench already, I willl probably leave it as a stand alone
    • Panzerwrecker
      • Mar 2022
      • 599
      • Los
      • Wales, UK
      I felt I overcooked the pin wash application using MIG neutral wash. It muddied the effect I was going for. Fortunately, as it was enamel based, I dialled it back with white spirit and just left the initial darker layer in selected areas.
      Click image for larger version  Name:	IMG_6037-2.jpg Views:	0 Size:	210.3 KB ID:	1248555
      Click image for larger version  Name:	IMG_6038.jpg Views:	0 Size:	232.2 KB ID:	1248556
      Click image for larger version  Name:	IMG_6039.jpg Views:	0 Size:	213.3 KB ID:	1248557
      To add another contrasting layer a selective pin wash with a lighter mud tone (AK splatter effects) was added. As this has a little texture it was also added over an application of chopped seagrass which had been fixed with VMS ballast freeze onto the running gear, glacis plate and track guards. This does unfortunately leave a few glossy tidemarks, but another round of airbrushed dusting will fix that.
      Click image for larger version  Name:	IMG_6044.jpg Views:	0 Size:	368.9 KB ID:	1248558
      Click image for larger version  Name:	IMG_6045.jpg Views:	0 Size:	402.4 KB ID:	1248559
      Click image for larger version  Name:	IMG_6042.jpg Views:	0 Size:	354.3 KB ID:	1248560
      The turret received a much lighter application of airbrushed dust, a very small pin wash of the lighter AK splatter effects and some seagrass was added and fixed in place onto the horizontal surfaces of the interior
      Click image for larger version  Name:	IMG_6050.jpg Views:	0 Size:	275.3 KB ID:	1248561
      Click image for larger version  Name:	IMG_6053.jpg Views:	0 Size:	277.5 KB ID:	1248562
      As I really liked how the previous airbrushed dust layers were shaping up, I plan to adopt the same technique but with a slight tonal variation to unify these new effects together on both hull and turret. I think if that all goes to plan, I should be able to move on to some OPR type stuff.
      Click image for larger version  Name:	IMG_6057.jpg Views:	0 Size:	411.0 KB ID:	1248564
      Click image for larger version  Name:	IMG_6060.jpg Views:	0 Size:	297.3 KB ID:	1248563
      • Richard48
        • 2175
        • Richard
        • Clacton on Sea
        Superb modelling.Jolly well done.
          • 16162
          That is weathering at its best. Superb work.
          • Steven000
            • Aug 2018
            • 2891
            • Steven
            • Belgium
            Very nice work Los 👍
            • scottie3158
              • 14565
              • Holbeach
              Very nice effects.
              • Panzerwrecker
                • Mar 2022
                • 599
                • Los
                • Wales, UK
                Thanks guys
                Par for the course slow progress but managed some progress with finalising the airbrushed dust effects inbetween other stuff last month. As usual, me being me, I got sucked into other projects way too easily. Oh look a bird????
                A slightly greyer toned mix of acrylic dust has been airbrushed over hairspray to the lower surfaces of both the hull and turret, and onto the turret floor to harmonise the previous dust effects and hide the fixing agent tidelines. Certain high wear areas of this new dust layer were removed leaving previous work exposed and again leaving dust coloured traces around detail. Mounting the Flak barrels and weathering the mount is up next.
                Tracks are just incomplete runs used for test fitment
                • JayCee
                  • Aug 2019
                  • 1147
                  Very nice, Los. I would be proud to achieve a finish like this.
                  John.
                  • Panzerwrecker
                    • Mar 2022
                    • 599
                    • Los
                    • Wales, UK
                    I have absolutely no idea where all the images have gone that were uploaded to accompany my last post yesterday? They uploaded and displayed yesterday but none are showing today!
                    I have just tried to upload them again and a warning message is informing me I can only upload a maximum of two images!
                    Is this a new thing or a temporary glitch in the matrix?
                    • PaulTRose
                      • Jun 2013
                      • 7089
                      • Tattooine
                      I have no problem seeing all the pics in the thread
                      Nice work by the way
                      Per Ardua
