1/35 Israeli Defence Force M60 A1 'Blazer'..
  • spanner570
    • 15599
    After making that IDF M-51 Sherman a few weeks back, I rather liked the look of this as a follow on.
    I don't use, nor want, after market stuff, so apart from some scratch built stowage clobber, this will be OOB. It might not be of much interest being basic, but I like all the nobbly bits on the tank.
    Here is the box art. I won't bore you good folks with the sprue shots.
    Cheers all,
    Ron
  • PaulTRose
    • Jun 2013
    • 6939
    • Tattooine
    look forward to seeing this go together
    at the starat of the year i did an Academy IDF M60 Blazer.....like to see how the two compare
    Per Ardua
    • spanner570
      • 15599
      Thanks Paul, but I can't wait, so I'm starting it tomorrow......
      I might come up with something for the 2017 G.B. Plenty of time to decide just what.
        • 22851
        Looking forward to seeing this come together Ron.
        • spanner570
          • 15599
          Thanks Ian.
          I was considering keeping it for the 2017 G.B., but when you reach a certain age, waiting isn't an option any more! O.o
          • Snowman
            • Oct 2014
            • 2111
            You are a no-nonsense man, Ron!
            I'll be watching! h34r:
            • spanner570
              • 15599
              No comedians please.........Officer on parade!
              Nice to have you along, Gavin.
              Seeing as how Mr. Sun refused to come out and play today, I did me the wheels, drive sprockets and some bits on the lower hull. No problems except the plastic seems a bit soft and burrs over easily when cleaning up. Meaning you have to constantly 'scrape' all the edges.
              Strewth, Shock absorbers!.......at least I presume that's what they are.
              Ron
                • 18291
                Nice choice Ron.
                Why put off 'til tomorrow what you can do today
                • Snowman
                  • Oct 2014
                  • 2111
                  The mold seems rather thin & "rough" for the lack of a better term, in your super clear close up of the wheels....
                  • spanner570
                    • 15599
                    Quite right too, Ian!
                    Gavin, at first glance, that is what I though, but it is in fact a clever bit of design. The thin looking top of the lower hull is actually a very fine taper, ending in a paper thin length of plastic. The upper hull slides inside this and pushes the thin bit out. Resulting in a perfect 'push' fit, with no gaps......Damn clever, what?!
                    Here is a picture of the joint. A loose fit, but you can clearly see the intended bulge where the two pieces join.
                    Ron
                    • monica
                      • Oct 2013
                      • 15169
                      real nice work so far on this one Ron,is looking good so far,very different setup from
                      a ww2 tank,
                      • spanner570
                        • 15599
                        Thanks Monica. They sure are different.
                        I've not much interest in modern armour, but since I started to build this, I am learning a thing or two. So it at least proves that the thing sat on my neck is still able to absorb information.......
                        Here is the completed lower hull a**e end.
                        ....and the front.
                        It annoys me when parts are moulded as one, when they are in fact separate items, as these boxes should be. But the kit has them as one piece, so I cut them into individual boxes.
                        Learning No.1....In my ignorance, I didn't know how this extra 'armour' worked, so for thicko folks like me, here's how.
                        The armour plating consisted of metal boxes lined with explosives that, once hit by anti-tank rounds exploded internally, crushing the projectile and thus preventing it from penetrating the tank......
                        EDIT - The above is duff info., please view Gavin's excellent video below.
                        Next up, the upper hull.
                        Ron
                          I love the complexity of Israeli tanks. Good job . I will watching you! I like it!
                          • Snowman
                            • Oct 2014
                            • 2111
                            Damn clever, what?!
                            Neeto!! B|
                            • Snowman
                              • Oct 2014
                              • 2111
                              The armour plating consisted of metal boxes filled with explosives that, once hit by anti-tank bullets, exploded internally, crushing the bullet and thus preventing it from penetrating the tank......here endeth the lesson.
                              I don't want to be a "kill-joy", but the "reactive armour" was created to defeat shaped charge warheads as you will find with RPG's and other anti tank missile systems.
