Tamiya M4A3E2 "Jumbo" Sherman in 1:35
    Hey guys! Back with another tank. All my other projects are on hold since this tank will be my Dad's Christmas present. I'm looking to replicate Cobra King as it appeared December 1944. I have a set of decals I'll order when I get paid next. Other than that, I think I have all the materials I need from the start!
    A quick review of the kit... The kit is from 1987. Relatively old! Despite that, the mold quality is excellent. Very highly detailed. It has some poly caps for the drive sprockets and idler wheels. The main wheels don't need poly caps as they are attached to the bogies, which are attached to the hull. The wheels roll freely. This means you can have the tank "drive" around when done! The kit comes with vinyl tracks. Here's the box art.
    All the parts for a bogey, before and after construction.
    Then came the lower hull. It is one big part with only slots for attaching the bogeys, drive sprockets, and idler wheels.
    All of them attached, and a shot of the rear panel with some work done. The exhaust mufflers, I will attach after the tank is painted because I will paint them separately.
    Then came the upper hull. I had to cut off and sand down some parts to prepare for the attachment of the additional armor.
    And after the armor was attached. The sides got the armor too. I really dropped the ball here; I used super glue and not cement because it would take ages to apply the cement with my little Tamiya brush/lid thing. By the time I finished the second half, the first would have already dried. I didn't expect the super glue to cure so fast, so the plates are slightly misaligned except for one of the sides (I don't remember which).
    Then I decided it would be a nice time to test fit everything together, minus the turret which wasn't started yet. As for the tracks, I tried to find some link-and-length tracks of this type (M48 track with "duckbill" end connectors) to no avail. I was going to buy a set of Friulmodel M48 tracks and the separate "duckbill" end connectors from Bronco. The total would have been over $40 with no guarantee it would actually work... See, I dread vinyl tracks after my experience with the first kit I ever made. It was a Trumpeter E-75 and it was a nightmare to find a glue that would keep the tracks "sagged" onto the road wheels... Fortunately these tracks in this kit are just right for this tank! They fit nicely with no problems and there's not much "sitting" needing to be done. They attach together very nicely too. I think all I will have to do is glue just a few spots on, and then melt the ends together. The tank rolls smoothly but you have to push it with some force to get all the wheels rolling.
    It was at this point that I received my PaK 43/41 anti-tank gun in the mail... I figured I'd need a couple shells for it and I remembered that Dragon King Tiger kit I finished had three brass shells included with it!! I pulled them out to put in the PaK 43/41 box and I decided I would do a size comparison. My GOODNESS look at the size of that shell! It's no wonder the long 88 made short work of whatever it fired at; that propellant charge is simply HUGE!
    Then work progressed on the upper hull. I'm leaving all tools and stuff detached for now; I will paint them separately.
    Turret parts! The main ones anyway. Before and after assembly, with a close-up of the cast texture. Nice job Tamiya!
    Then the little parts went on. I'm leaving off the coaxial MG to paint separately.
    And a full fit of the whole tank! I'm also leaving off the roof MG to paint separately.
    About this time I was really getting bothered by a few things... There was no underside plate for the sponsons! And that little protrusion in the back of the turret is empty underneath! I don't know if this is laziness on Tamiya's part or simply the technology in 1987 couldn't make it possible. If that's the case, I'm fine and I understand. Here is what I mean.
    I decided to address the sponsons first... This was my first "hardcore" fix on a kit. I had to take precise measurements and mark the outline of what I needed to cut out on my trusty Evergreen plastic sheet... Tedious and took a couple tries!
    And it paid off! I had to re-glue the left piece several times. It kept messing up. I decided to add little "supports" inside the upper hull, to brace the long pieces I cut out for gluing.
    The sealed sponsons!
    Then came the turret thing. It is small so I tried to cut out a small bit of curved plastic. It didn't look right, even after I took measurements... I figured it was a good time to break out my Tamiya putty for the first time! I got the hang of it quick. The pictures are: immediately after applying and shaping, then a day after when I sanded it and stuff. I also had to snap off the bits on the end because they got in the way of my grip. I re-attached them and applied putty to the gaps today which I will trim down tomorrow. I think the middle part came out nicely. I will tidy it up when I prime and paint! That will make it much smoother.
    Another thing that I had to fix was the loader's periscope. The kit didn't include one! I had to grab a spare from my Dragon Tiger II (I'm sure it's not at all what the Americans used lol but it's all I have) and filled in the gaps in the side with some more putty!
    And that brings us to the present! Was fun working on this so far. Not a lot of parts; I'm glad Tamiya keeps it simple with this one! I hope my dad likes it when he's finished. Nobody tell him! The idea behind choosing Cobra King for this one was... See, he really likes the book "Killing Patton" by Bill O'Reilly and admires Patton as a whole. In that book, Cobra King is mentioned as being the first tank in Bastogne, as it was in reality. Hence the painted on words. Lol! Because no other tank was singled out in that book as being under Patton's Third Army (plus Cobra King's historical significance), I decided to go with Cobra King. If anybody has reference pictures of it in 1944 except for that one taken from its left side (I already have that saved), I would be very grateful.
    That's all for now. I will continue tomorrow with the tools hopefully. I want to have the tank itself primed on Wednesday, as I will be off work with plenty of time to work on it. Post your thoughts!
  • monica
    • Oct 2013
    • 15169
    very nice progress,and do like how your laying it all out as you go along, ,your review,
    I have a sherman for next years GB,I do real like how you add in the plastic ,cover over the tracks,it,s some think I,mean to do on a lot of build, :/
    very nice so far will be sitting in on this one,
      Thanks Monica! Always nice to have someone interested.
      I sanded down the putty on the rear turret things just now. It looks good!
      • Peej
        • Aug 2014
        • 919
        Very interesting. I will be watching this build as I am thinking about giving planes a break and doing something along these lines. (If only I could decide which one to go for!)
          Personally, I love the mid- and late-war German tanks. I have four Tiger IIs alone. xD  I just never liked the look of the other narions' tanks. Not to mention Dragon makes AWESOME German tank kits.
            I must build a Sherman sometime soon! Maybe for next year's GB, but until then I'll watch this one take shape.
            Patton was a very interesting character, although I dare say his reputation might well be somewhat different on either side of the Atlantic
              I agree. xD  History and its people change with whatever side of the campfire you sit at. ^_^
              As for Shermans, I also have a newer Tamiya M4A3E8, but I used this Jumbo for my dad since it will be a tank he is more familiar with.
                Nice job so far, Ryan.
                That kit brings back some memories... I got it when it first came out! And you are giving me flashbacks. This kit was the first one that I sealed up the sponsons, and I did it pretty mush like you did. I like seeing some good, old-fashioned modeling techniques for taking care of stuff like that.
                  I love nostalgia, such a great feeling. Glad I could give you some, Brett.  Whenever I have kids, Lord willing, I will teach them scale modelling. I want those "back in the day" moments. (: That aside, making fixes like that was a lot of fun! Made me feel like a big boy modeler.
                  Update! I got the tank primed and the tools cut off and primed as well.
                  I decided to keep primer out of the little slots to which the tools connect, so as to make cementing them easier. I just pulled off little pieces of sticky tack, rolled them up into balls, and stuck them in the slots!
                  While I was at it I decided to use my newfound putty skills to fill in a gap on my Panther II's gun mantlet. It went pretty well!
                  I've started painting the tools and will show them when they're all done. I'm going to the local hobby store tomorrow to get paint for the tank itself; forgot I didn't have any!
                  • monica
                    • Oct 2013
                    • 15169
                    very nice work so far on this one, Ryan ,will be waiting to see your progress later on,
                      Update time! It's small but progress was made. I painted all the tools. Didn't take as long as I expected, and everything looks so precise. Tedious work, but I'm happy how they turned out! They will all get a wash after being attached to the tank when it's painted, so they won't look this clean/shiny in the end.
                      A close up of the .50 cal. In my opinion, this was my best work in this group. I had to refine the handles and bolt a couple times. :P  I love it!
                      And lookie here! I bought this recently. M35 stahlhelm! It's an exact replica of an M35, not one that saw combat. Still though; it's all steel, 1.8mm thick. Comes with the leather and everything so you can wear it. This thing is heavy!  It looks so awesome though; I love stahlhelms. All it's missing are the emblems on the sides... I'll see what I can do about that.
                      I got this for $85, and it was well worth it. Authentic stahlhelms cost so much more and usually don't come with everything...
                      Anyways, I will try to paint the tank itself on Wednesday when I am off of work.
                        Tank is done with the olive drab coat!! This was so much faster than my Tiger II, obviously because I didn't have to recreate the ambush camo and use three colors.
                        After the primer and paint, I'm happy to see the turret retains its molded cast texture!
                        So for the wheels, I found out I can easily paint the contact surfaces (I know they're rubber so I'll cover them with rubber black) by just aiming the airbrush air stream at the wheel at a steep angle, which makes it spin rapidly. Then I pull back on the trigger for paint flow, and the wheel practically paints itself! I love physics!! Here are two gifs to demonstrate what I mean.
                        Next step, minor fixes to the paint and making a couple details that I forgot. See y'all!
                          Oh, what color do you guys suggest I paint the light on the turret and the viewports on the various periscopes?
                          • monica
                            • Oct 2013
                            • 15169
                            I mostly use a translucence,lite blue,with a dark blue line on the bottom,
                            hope you like the sounds of my idea,
                              Looking very good there Ryan, love the work on the gun, with the light, I use Bare metal foils then cover that up with a clear part,
                              See here the back of this part is covered in foil
                              Also see the light on this model I have used bare metal foil as the back, then cut out a circle from a clear sheet of styrene and glued it on with PVA glue
                              Hope that helps! There are many ways to do it though.
