This is Tiger commission build.
I have, drilled out the vision slits, removed the duplicated parts-rear convoy light, aerial tube, moved the commanders cupola to the correct position. Added armoured transmission covers, correct light added with cables added, PE debris grilles, aerial moved and I made a whip aerial and positioned it in the correct place, turret lifting mushrooms sorted, added grab handle to front-some Tigers had it some didn't.
Main detail is damage as he wanted it to look like it had taken a mauling but was still running.
Still more to do and tidy up before a primer coat can be added.
