Roberts 1/35 Tamiya Russian SU 122 Winter warrior ( test bed)
  • Robert1968
    • Mar 2015
    • 3596
    Hi guys and gals
    This is a quick one for me ( hoping ) I'm more practicing before I start my two bigger in depth kits for the GB in August.
    It's an older kit but seemed to go together with no issues except the tracks are a bit tight ( rubber band type of old Tamiya kits.
    Although this is more a test bed for my upcoming builds I still want to make it look good and it will go with the Russian sector of tanks
    I've got a little help from advice from over the pond in the guise of Monica.
    Once complete the main build I sprayed the model with XF69 NATO black then once dry used Xf61 light passes to give me shadows and help the weathering
    She will have a coat of hairspray once painting stages complete so I can winter wash the whole model white then start on the weathering. I made my own tow rope stowed on the vehicle and once painted up should be acceptable
    Comments welcome
    [ATTACH]284568[/ATTACH] [ATTACH]284569[/ATTACH] [ATTACH]284570[/ATTACH] [ATTACH]284571[/ATTACH] [ATTACH]284573[/ATTACH] [ATTACH]284574[/ATTACH] [ATTACH]284575[/ATTACH] [ATTACH]284576[/ATTACH] [ATTACH]284577[/ATTACH] [ATTACH]284578[/ATTACH] [ATTACH]284582[/ATTACH] [ATTACH]284584[/ATTACH]
    • 22983
    A great start Robert.
    • Robert1968
      • Mar 2015
      • 3596
      Postie bought me a lovely welcome gift this morning but maybe it's a nightmare???
      As the Su122 tracks from Tamiya are a little neat ( band type ) I ordered some T34 wafer type workable tracks by Miniart.
      Now most T-34 and simular based tracks like su85/Su100 it seems they have 36 horns and 36 flat pieces ( 72 each side total
      I've decided to take it to 40 each ( 80 total and see if I need less to produce a wee sag
      Now mini art say they a workable but after trimming off a few pieces they do lock together but will need a touch of glue in the centre otherwise they will fall to pieces.
      Lots of cleaning ahead
      [ATTACH]284609[/ATTACH] [ATTACH]284610[/ATTACH] [ATTACH]284611[/ATTACH] [ATTACH]284612[/ATTACH] [ATTACH]284613[/ATTACH] [ATTACH]284614[/ATTACH]
        • 22983
        Yes lots of FUN ahead Robert, It was the same with the tracks I used for my Scorpion build.
        Have a swear jar to hand
        • bazers
          • Oct 2013
          • 2611
          Looking good Robert, be interesting to see how the winter camo works out .
          • Robert1968
            • Mar 2015
            • 3596
            Oh for Fxxxxxxx I just finished the 80 + 80 put in two plastic beakers and I just dropped one
            Now to pick up aghhhhhhhhh
            • Robert1968
              • Mar 2015
              • 3596
              Next stage was the hairspray tech
              I gave the model a complete clear coat and once dry inhairsprayed the complete model including wheels etc
              I thin once dry gave the model a light coat of off white XF2 and started the winter wash using water and coton tips
              Still some way to go but here's progress pics
              [ATTACH]284640[/ATTACH] [ATTACH]284641[/ATTACH] [ATTACH]284644[/ATTACH] [ATTACH]284645[/ATTACH] [ATTACH]284646[/ATTACH][ATTACH]284643[/ATTACH]
              • monica
                • Oct 2013
                • 15169
                this is looking good,Robert,nice work with your weathering,
                will like to see the tracks,once you get a good start into them,and you should,be able
                to get the right sag in them as well,
                • Robert1968
                  • Mar 2015
                  • 3596
                  Thanks Monica
                  I have still yet to do more weathering and rusting effects around the bolts and exhausts and wheel bolts
                  Some mud and dirt
                  I should get the tracks sorted in the next few days.
                    Superb weathering Robert, looking very good.
                    • Razzie43
                      • Oct 2015
                      • 397
                      Hey Robert,(edit text here)
                      And i like the way you try this one...it's special
                      I saw somewhere (i never try).First the white and then the green with a worn effect(like a HairSpray kind of way)
                      I wanna see the end of this...
                      (edit this also)
                      Why not with a brush very wide and flat in some water?
                      And the way you spray the last layer is to tick to remove it for the first time..
                      i mean : You can repeat the it with white again
                      and did you spray the whole tank in one shot?
