M2A1
  • scottie3158
    • 14491
    • Holbeach
    #196
    Originally posted by Jim R
    Hi Scottie
    Just great. Top modelling skills. Really look forward to your updates.
    Thanks Jim, for the kind words and hanging in there with the build.
    • Allen Dewire
      • 4741
      • Allen
      • Bamberg
      #197
      Evening Paul,
      The house is fine the way it is and I love the way you use a variety of materials to do it. Top work my friend! This whole project is turning into a first class dio and up to your usual high standards. Drive on!!!
      Allen
      • scottie3158
        • 14491
        • Holbeach
        #198
        Allen,
        Thanks my friend it's great to hear from you, glad your liking it so far.
        • Si Benson
          • 3572
          #199
          Hey Scottie,
          Building looks great from here, you’ve made a nice job of the frames and shutters...........nice bit of micro carpentry :thumb2:
          Handrails sound like a nice touch....had you thought about adding a small porch/ canopy type thing above the door?
          Keep up the good work mate :thumb2:
          • scottie3158
            • 14491
            • Holbeach
            #200
            Originally posted by Si Benson
            Hey Scottie,
            Building looks great from here, you’ve made a nice job of the frames and shutters...nice bit of micro cap entry :thumb2:
            Si,
            I like the sound of that will give it some thought
            • Steve Jones
              • 6615
              #201
              The guys have said it all Paul. Stunning work. I am glad you went the extra mile:thumb2:
              • scottie3158
                • 14491
                • Holbeach
                #202
                Steve,
                Thanks mate, Having looked at the pictures and the build again I am going to re do the shutters the balsa is far to thick, and there are a few other things I will look at again.
                • Wookie2486
                  • 233
                  • Marty
                  • Yeovil
                  #203
                  Scottie
                  Just caught up the half track looks brilliant. The building is awesome are you going to do cobblestones on tje base.
                  Marty
                  • scottie3158
                    • 14491
                    • Holbeach
                    #204
                    Originally posted by Wookie2486
                    Scottie
                    Marty
                    Thanks Martyn,
                    Good to see you, thanks glad you like it. The plan was to just have a dirt base but I think your right cobbles would look beter. I am open to suggestions
                    • Neo
                      • May 2018
                      • 526
                      #205
                      Hi, Scottie! Very well done! Good work with PE and wire:thumb2:
                      • scottie3158
                        • 14491
                        • Holbeach
                        #206
                        Neo,
                        Thanks fella I will be giving this a few tweaks as not happy with it at the moment.
                        • scottie3158
                          • 14491
                          • Holbeach
                          #207
                          Just as you thought it was safe to come on here, I'm back. Work progresses on the base. I have redone the shutters from plastic card instead of balsa as they were far to thick. I scribed in the planks then using the teeth of a fine saw I scratched in the grain. Next the furniture was added to the shutters and everything was blocked in with yellow. when everything is dry I will add some more details. The walls received a wash to give it that lived in look. Again when dry some more details will be added. As you can see it is only pinned together at the moment.
                          Any comments or criticisms will be greatly received.
                          [ATTACH]316902[/ATTACH][ATTACH]316903[/ATTACH]
                          • Steven000
                            • Aug 2018
                            • 2849
                            • Steven
                            • Belgium
                            #208
                            Interesting base Scottie, looks good. Looking foreward to the next steps.
                            Kind regards,
                            • scottie3158
                              • 14491
                              • Holbeach
                              #209
                              Steven,
                              Thanks fella, stay tuned lots of detail to add yet.
                              • scottie3158
                                • 14491
                                • Holbeach
                                #210
                                Just a little bit more, the outhouse doors have been added made from coffee stirrers plastic strip for the hinges and pewter bolt heads. next a small bit of chain and a scratched padlock. then a wall anchor (not sure if that is the correct term) was scratched and added. lots left to do.
                                Thanks for looking.
                                [ATTACH]317456[/ATTACH][ATTACH]317457[/ATTACH]
