M2A1
  • Si Benson
    • 3572
    #121
    Morning Scottie,
    Lovely work on the headphone wiring, a nice touch:thumb2:
    • scottie3158
      • 14638
      • Holbeach
      #122
      Steve,
      thanks mate I am still practicing as well, It is a bit heavier that I wanted but with a bit more work I can hopefully get it the way I hoped.
      • scottie3158
        • 14638
        • Holbeach
        #123
        Si,
        Thanks fella, they are far from perfect but hopefully they add a bit of interest.
          Scottie this a wonderful build of yours soo many photoetch and details and you sir will certainly due justice with it! Can’t wait to see it finished! Regards Danny
          • scottie3158
            • 14638
            • Holbeach
            #125
            Daniel,
            Very kind of you mate, If it turns out as well as your last build I will be happy.
            • minitnkr
              • 7809
              • Dayton, OH USA
              #126
              Great details, and execution. The more MGs the better. GIs were notorious scroungers, grabbing up anything of potential use not guarded or securely fastened. MGs to "fight the track" would use the attached cans so as to not require a full time assistant to keep the belt from fouling. PaulE
              • scottie3158
                • 14638
                • Holbeach
                #127
                Paul,
                Thanks mate, your right squaddies are great scroungers, I have seen pictures of M60's using cans in Vietnam.
                  I get the impression you’re not talking of the same type of cans here The first Paul (minitnkr) probably means an ammo can hanging from the machine gun mount so there’s no loose belt flapping all over the place:
                  (source)
                  while the other Paul (scottie3158) seems to mean using a tin can underneath the feedway of the gun to allow it to be fired without a loader making sure the belt is pulled in horizontally to prevent jams:
                  • scottie3158
                    • 14638
                    • Holbeach
                    #129
                    Originally posted by Jakko
                    I get the impression you’re not talking of the same type of cans here :smiling3: The first Paul (minitnkr) probably means ammo cans attached to the machine gun mount:
                    (source)
                    while the other Paul (scottie3158) seems to mean using a tin can underneath the feedway to allow the gun to be fired without a loader who makes sure the belt is pulled in horizontally to prevent jams:
                    Hi Jakko, yes I was thinking of the can under the belt.
                      In that case: don’t add one to your model This is something you see almost exclusively with M60s in Vietnam, and even then only on pintle mounts, door guns, etc. where there wasn’t enough room for a loader to work. (Revised M60s have a sheet metal bracket on the left side that fulfills the same function, so the can is also not appropriate on a model of, say, an American vehicle in 1970s–’80s Germany or the Gulf War.)
                      • minitnkr
                        • 7809
                        • Dayton, OH USA
                        #131
                        Correctomundo. Jakko's first pic is exactly what I was referring to. Often the unwieldy water cooled were utilized to "fight the track" or jeep mounted, while the air cooled were saved for ground mounts due to the weight difference. The late war biped/rifle stock equipped 30cals were even lighter. PaulE
                        • scottie3158
                          • 14638
                          • Holbeach
                          #132
                          Not getting a lot of time at the bench, but have managed a little bit. I have attempted to make some tarps and bed rolls. Please ignore the twine it will be removed it was used to pull the putty in ready for the straps to be added later. The large tarp on the side has a hole in it as the more observant will have noticed it was my mistake but I actually like it adds a bit of wear.
                          Thanks for staying with this.
                          [ATTACH]315506[/ATTACH][ATTACH]315507[/ATTACH][ATTACH]315508[/ATTACH][ATTACH]315509[/ATTACH]
                            • 16310
                            Hi Scottie
                            Looking good. I like the used and abused tarp - seems that would be the case in reality.
                            • wotan
                              • May 2018
                              • 1189
                              #134
                              Scottie
                              Keepin' it real man! Or something like that in new speak. Anyway great job sir.
                              • BigGreg
                                • 2186
                                #135
                                Love the Tarps and the natural bending... i find the rope a bit to big... is it me???
