Si B’s- Academy Hetzer early....
But what were those hard gritty bits ???Comment
Using all the tools in the kitchen - she is down there now - lost three dogs and a pair of wellies, sounds like a mad mans drum kit, I need a cup of tea, but there is no way I am venturing into that madhouse,
[ATTACH=CONFIG]n[/ATTACH]
...and that is just peeling the carrots..... Mike.Comment
:smiling5::smiling5::smiling5: She’s not trusted with metal ones!Comment
I see faithful hound is patiently waiting for something to drop on the floor:smiling4:Using all the tools in the kitchen - she is down there now - lost three dogs and a pair of wellies, sounds like a mad mans drum kit, I need a cup of tea, but there is no way I am venturing into that madhouse,
I miss my dog so much, I rarely had to sweep the kitchen floor after cooking:smiling5:Comment
Don’t worry Graeme, Johns got one in his pocket that he saved for you....mind you it’s been in there since yesterday and I think he wrapped it in his handkerchief :sick::tongue-out2:Comment
Tonight update inbound......
So with some questions answered about the details, I set to adding a couple of bits.
First up was the extra track holding clamp on the rear hull...
Then made up the missing two hooks that should be on the rear hatch, for the tow cables to be hung on...I remember Mike C, saying about flattening copper wire, so I had a go myself to make the hooks. The exact positions are a bit hazy as there seem to be small differences between vehicles made at different factory’s. So somewhere on the rear hatch seems the norm:smiling5:
Side skirts attached, leaving one piece out one each side.
And then she gets her little trunk!
So very nearly there now, just the MG mounted up top and it’s pretty much done
Thanks for lookingComment
Get another, we have two and a half Bassets, the other half is Beagle, and came with the Beagle attitude, but she is starting to settle now, cost a fortune in vallium and other relaxing non medicines....Comment
Si,
The build is coming along great, but that yellow plastic
. Still more good stuff to come.
Cheers, Mike.Comment
Thanks very much Mike:smiling4:
The kit plastic isn’t really that yellow. That blue background seems to make it look worse....think I’m going to look into a light tent thing:smiling3::thinking:
Ok, so it’s done:smiling4:
It’s all together apart from tow cables which I’m in the process of making. As mentioned, the wheel and tracks are not glued up, neither is the hull top and bottom or the MG so I can pull it apart for paint.
A very quick simple build. I’m going to ditch the Tamiya paint and go for airbrushing acrylic , something which historically gives me trouble!
