Shenanigans 4: Italeri 1/35 M6 Gun Motor Carriage
    [ATTACH alt="329175"]329175[/ATTACH]
    I got this to add to my last armour build, but decided to do it as a stand-alone. I had anticipated three crew members serving the gun, re the box art, but the kit just includes a rather poor driver figure (it's an old re-boxed Airfix offering). I had anyway ordered these Verlinden figures, which should fit very well:
    [ATTACH alt="329178"]329178[/ATTACH][ATTACH alt="329179"]329179[/ATTACH]
    These look superb. They would have put the Tamiya figures to shame if I'd used them in the same dio.
    The sprue shots for the M6:
    [ATTACH alt="329176"]329176[/ATTACH][ATTACH alt="329177"]329177[/ATTACH]
    Looking them over it seems that the toolmaker was terrified of the thing sticking in the mould as there are raised release points on every part, including the front grill:
    [ATTACH alt="329172"]329172[/ATTACH]
    That will take some delicate clean up. Some of the parts are also pretty poorly done. These are meant to be carbines in leather holsters:
    [ATTACH alt="329173"]329173[/ATTACH]
    More like medical crutches. These will probably be dropped and replaced.
    I decided to get started and have built the chassis:
    [ATTACH alt="329174"]329174[/ATTACH]
    I've only ever built one of these Italeri kits before and I had forgotten what they could be like. Apart from the mould release scars, there was also quite a lot of flash, and seams running through everything. Added to that, a so-so fit of parts, lack of locating pins, and unclear instructions and the air was soon turning blue. However, I got it done, and will now give it an initial coat of paint before getting on with the bodywork.
  • Steve Jones
    • 6615
    Blimey Peter! Is there no stopping you?? :smiling:.
    We are certainly being treated to a fest of PDiddy masterpieces. From armour to busts and back again. Take care with the figures. They certainly look the DB's. Will be paying full attention on this one. Good luck my friend
      • 16165
      Hi Peter
      Not the best of kits by the sound of things but you'll work your usual magic. Figures do indeed look good. Bet they cost more than the kit :smiling3:
        Steve - I've got the bit between my teeth.....
        Jim. I'll give it my best shot. KIt £12.99, figues £13.55.
          This is a very old kit that goes back all the way to the MAX Dodge weapons carrier released in 1974; the 37 mm M6 GMC was first released by Peerless Max in 1976, and was indeed also put out by Airfix a few years later (all according to Scalemates ). This goes a long way to explaining why it’s going to take some work.
            Cheers Jakko - Yes, explains a lot. I hope it doesn't defeat me.
              I’ve built the 6×6 version (a decade or two ago) and found it basically sound. Sure, it may take a bit more work than a state-of-the-art kit, but I’m sure it won’t be all that difficult, given your good job on the 75 mm M8 GMC for example. It's not like you’ll be trying to put together a SKIF kit
              • BigGreg
                • 2186
                And it begins... I'm in....looking forward to this.... ;-)
                  Jakko - I must admit that the chassis looks OK now that it's together - at least all four wheels rest on the ground. I made the Italeri ambulance jeep a couple of years ago, which I presume is of similar vintage and that came together in the end, despite having similar issues.
                  Greg - Just a small set-up this time. Welcome aboard.
                    If you’ve got a softskin kit that has all four wheels on the ground, everything else is easy
                    The Jeeps are original Italeri models, so they may be quite different in design than the Beeps, even if they were released around the same time.
                    That said, I always liked the Italeri Jeeps too
                      Hi Jakko - I don't think I've ever got all for wheels to rest on the ground, so I'd say it's a win so far!
                      [ATTACH alt="329228"]329228[/ATTACH][ATTACH alt="329230"]329230[/ATTACH]
                      I've painted the underside in mud colours and also painted the wheels, which will be weathered later. You'll notice a few seam lines etc underneath, but these have been left for obvious reasons (it won't be displayed overturned in a ditch).
                      • SteveH
                        • 1287
                        Morning Peter
                        Just the right day to spend it at the bench modelling!
                        Good start with all 4 wheels on the deck, the kit does show it age, but I am sure it will be whipped into shape.
                        The figures look OK too, better than the last Tamiya ones.
                        I really did thing the armour modellers might get more than a couple of days relief from your speed building, but it seems not!
                        Have a good day at the bench.
                        Off to comment on your superbly painted Germanic bust
                        Regards
                        Steve H
                          BINNED!!!!!!!!
                          A truly appalling kit. The sub-assemblies for the cabin and bonnet went OK, but then they just wouldn't fit onto the chassis. Part of the problem was that the rebate to take the bottom of the radiator was too narrow - I ended up cutting it off, then found that the chassis was too wide to take the bonnet sides. Any attempt to make it fit just caused gaps between the panels. Each miss-fit then had knock on consequences for the fit of the subsequent parts.
                          My fault for buying a cheap and very old kit. I'll probably continue with the figures and make them up into a little vignette.
                          • Mike Mortimore
                            • 202
                            Hi Peter,
                            Sorry to hear of the ''binned'' item.... I've built quite a few of the WC carriers in different forms. but not this one, will steer clear I think.
                            So what is going to be your next challenge??????
                            Regards Mike :sleeping::sleeping::sleeping::sleeping::sleeping:
                              Hi Mike. It really was a big pile of pooh! I'm carrying on with the figures, to make up into a little vignette.
                              To try and compensate for the disappointment caused today's debacle I constructed the figures and started painting the first:
                              [ATTACH alt="329271"]329271[/ATTACH][ATTACH alt="329272"]329272[/ATTACH]
                              These are lovely to paint, though the face was a struggle. Still very shiney - apologies.
