Dave Ward's Vulcan 1/35 Light Tank Mk. VIB BEF
Name:	vulcan lt tk.jpg
    On the final stages of my eggcopter, and the IT-1 Tank, I've decided on this for the next build. It's going to be OOB - the model itself is pretty detailed. I'm going to paint it with these.........
Name:	hataka british afv.jpg
    I'll be putting up some sprue shots before starting construction, but this is a taster of what I can expect
    These springs, and rodsClick image for larger version
    Go into the suspension - the instructions as to where they fit are a bit 'busy'Click image for larger version
    The tracks are link and length - if they had been individual links, I would never attempt this!
    Construction will start shortly
  • scottie3158
    • 14578
    • Holbeach
    That will test your sanity, looking forward to this.
      • 22954
      Looks like some fun ahead Dave.
        OOOooooooooo!!! you're going to be sorry. If not already started on the suspension,
        C/a part B3 onto end of pin, feed through A5, 6, 7 or 8 as you feel comfy with, feed in springs - add part A19 - add second set of springs, now for the juggling act, feed as an example the end of the pin through the part A6 from part A8 and slight ly conpress the spring. With a dab of C/a on the end add the adjusting part B3 and wait for it to dry. Once you have the springs on say parts A8/A6 and A5/A7 then go for final assembly. If you lose parts I think I have spares in the stash - pm me.
        Meanwhile....
        [ATTACH=CONFIG]n[/ATTACH]
        Apart from a headache, this is as far as mine has reached to date...
        Cheers, Mike.
          Mike,
          are you trying to put me off!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          Dave :cold-sweat:
            Mike,
            Dave :cold-sweat:
            Bite the bullet, think of England and St George or is it Georgy in this pc world, I give up! About two days should see you through this part working slow and steady. You could of course cut it down to half an hour in a black bin bag and a torch, that way you will not lose anything, but do not touch sensitive parts, you may have c/a on your fingers. And remember, you are not doing this for yourself but for all the modellers everywhere :tears-of-joy:.
            Mike.
            • Jon Heptonstall
              • 1705
              Ooooh. Looking forward to this Dave.I've got it in my little stash.Taken it out a couple of times,had a good look and quietly put it back again!
              Jon.
                • 16169
                Hi Dave
                Not heard of Vulcan Models before. The kit seems to have a "reputation". Good luck.
                  Vulcan Models made a few models ten years ago, but seem to have vanished. A few sprue, and part shots...........................Click image for larger version
ID:	1087053Click image for larger version
ID:	1087048Click image for larger version
ID:	1087049Click image for larger version
                  Link and length tracks - still a bit small!Click image for larger version
ID:	1087052Click image for larger version
                  Decals, a little PE fret, a few hatch parts, and that bag of springs and rods.................Click image for larger version
                  I'm going to have to think about the sequence of painting, and build, to minimise problems
                    Vulcan Models made a few models ten years ago, but seem to have vanished. A few sprue, and part shots...........................[ATTACH=CONFIG]n1087053[/ATTACH][ATTACH=CONFIG]n1087048[/ATTACH][ATTACH=CONFIG]n1087049[/ATTACH][ATTACH=CONFIG]n1087050[/ATTACH]
                    Link and length tracks - still a bit small![ATTACH=CONFIG]n1087052[/ATTACH][ATTACH=CONFIG]n1087051[/ATTACH]
                    Decals, a little PE fret, a few hatch parts, and that bag of springs and rods.................[ATTACH=CONFIG]n1087047[/ATTACH]
                    Dave, pm me and I will send you an outline template for the tracks, save you struggling with trying to get the tracks onto such a small model.
                    Cheers, Mike.
                    • Jon Heptonstall
                      • 1705
                      Originally posted by Jim R
                      Hi Dave
                      Jim. This looks to be an excellent little model but skills in advanced microsurgery would be an advantage.
                      Jon.
                        • 18302
                        So working Suspension and solid tracks.... Hmm. Still an interesting build to watch.
                        Am I correct that they are the same tracks as a 'Universal/Bren carrier'.
                        If the springs and rods dont drive you nuts, you could try and get the single link tracks for it... LOL:tears-of-joy:
                          No, Ian, I'm not going to make things any worse than they are now! :fearful:
                            I don’t think the idea is to have a working suspension, but to have one that replicates the springs well, which is rather hard to do in plastic.
                            Am I correct that they are the same tracks as a 'Universal/Bren carrier’.
                            I’m not sure they were 100% the same and interchangeable, but they certainly didn’t differ much. I wouldn’t want to put together loose track links for any of these, I think.
                              Dave,
                              If it is any consolation, I scratchbuilt one of these back in 1978, used the now defunct Profile publications booklet for the plans. The whole thing was scratch from the tracks to the rivets, no resin just pure plastic. Your item in now in progress.
                              Cheers, Mike.
