Takom 1/35 Jagdpanther G2 with Interior
  • morph
    • May 2018
    • 16
    #16
    Originally posted by Jack L
    Have put some more of the interior together...need another painting session before going any further:[ATTACH=CONFIG]n1091505[/ATTACH]
    Next process also requires the shells to be painted up. I can't decide whether to paint the kit shells from scratch, or try and take the shell and attach to the brass/ionised cases. Has anyone tried the latter? [ATTACH=CONFIG]n1091506[/ATTACH]
    Those brass/ionised cases look sweet
    • Jack L
      • Jul 2018
      • 1285
      • Cheltenham
      #17
      Thanks...the brass is pretty bright/shiny, but want the detail to 'pop' a bit when it is closed up.
        Jack,
        This is looking alright, do not bother with cut outs, leave all the hatches open, then watch the viewers get eye strain trying to focus in on all that detail....
        Keep the good work coming.
        Cheers, Mike.
        • Jack L
          • Jul 2018
          • 1285
          • Cheltenham
          #19
          Couple more WIP shots. The upper hull came pretty warped, so been tricky getting that re-aligned. I am a little nervous about the final fit, especially with the upper panel removable, but the dry fit isn't too bad. I have some 2mm LEDs so toying with the idea of installing one in the hull (more a question where the switch and battery go). Click image for larger version
ID:	1091823Click image for larger version
ID:	1091824Click image for larger version
ID:	1091825Click image for larger version
