Bronco Comet plus bits....
    Looks like it will be another great model
      I have the resin Nuffield engine for this if your interested.
      Scottie,
      Further to your kind offer, I cannot accept as I cannot now get the engine in place without ripping the back half off.
      Mike.
        Bathroom looks good, are you allowed in or is it still the bucket in the shed for your ablutions.:smiling:
        Plenty of PE by the looks of it Mike, looking fwd to seeing the build .
        No, it's still me and the pigs in the pen....:sick:
          Originally posted by SimonT
          Hi Mike - bolt end missing from nut on second road wheel
          They had a Comet at Beverley Museum of Transport that I used to visit regularly - probably have some actual photos (way back before digital appeared) somewhere
          Simon
          There is always one - one on every forum, there is always one!!!! :tongue-out3:
          I noticed that on the pic, and no matter how many times you look there is always one that gets through, and just checked, you found the only one.
          Mike.
            Originally posted by Jim R
            He's right - super human vision :smiling5:
            B***** nitpicker.....
            • scottie3158
              • 14581
              • Holbeach
              #21
              Originally posted by MikeC
              Scottie,
              Mike.
              No worries Mike it appears it is the wrong engine anyway.
              • SimonT
                • 2824
                #22
                :thumb2:
                Well someone has to keep an eye on you lot :smiling5:
                • BigGreg
                  • 2186
                  #23
                  and another great build from Mike... :thumb2: :thumb2: :thumb2: :thumb2: :hugging-face::hugging-face:
                    We shall see - not there yet...
                      I met a second hand car salesman like you once....
                        Update - and the brass begins....
                        Having now had a look through the 12 sheets of brass I accumulated for this build I can see there are a few duplicates that can be ignored. So starting from the back of the hull it was tine to replace the grill and shrouds.
                        The kit has a set, the Eduard has a set and the Voyager has a set, although for some reason the Bronco kit has two sets , don't ask, I only build them.... After some checking and deliberation I chose the Voyager set, these are better detailed and there is not so much of a gap between the two. But if you look at the rear of 'Celerity' there is quite a gap, so you pays your money and you takes your choice, as both types were in use. Now the inside was given a coat of surface primer black, and once dry construction commenced...
                        Obviously the first job was to cut off the engraved mesh flush with the end of the engine deck. Onto this I then built up the opening with 1mm square rod to bring up the height and to replace the surround. Now Voyager give you this surround but as the brass is so thin this then formed the surround on three sides and a thin strip added to the engine deck side to add support....
                        [ATTACH=CONFIG]n[/ATTACH]
                        The strip is not cemented in place in the pic as I wanted to have a firm attachment point and then cement to rest. Once dry this was all cleaned up ready for the mesh.
                        Here you can see the grill in place, and before the clean up started. A word of warning the Voyager grill is wafer thin, if you breathe on it, it will bend - I had to roll this flat twice....
                        Next it was the shrouds themselves. I did forget to take some pics of the build up of these. But here I deviated from the fold it and roll it sequence. I first cut off the side frame/panel for each side. I then heated up the part to be curved and once cool rolled this to shape and then c/a'd the side frames after bending the lip to shape. The shrouds were then attached to the mesh surround...
                        As can be seen there is still some rod to be put between the two shrouds...
                        Although not very clear there is also a strip across the rear and arond both sides at the base of the shrouds....
                        ...and the securing pins on the four plates. Both supporting strips in the middle of each shroud are straight, this is just an optical illusion that has them looking bent outwards.
                        And that is it for this part, more brass later..
                        Mike.
                          • 16190
                          Hi Mike
                          Beautifully neat and sorted work as always.
                          • scottie3158
                            • 14581
                            • Holbeach
                            #28
                            Mike,
                            Excellent work as always.
                            • Lee Drennen
                              • 7738
                              #29
                              Looking smart Mike
                              • Allen Dewire
                                • 4741
                                • Allen
                                • Bamberg
                                #30
                                Ohhhh Lawdy Mike,
                                I like it as I have the same one in the stash (green plastic). I'll just sit in the back and rip off all your ideas for mine when I build it. Looks like a bling fest to me!!! BTW, nice job on the Loo too...…….
                                Allen
