SimonT - 1/35th Tamiya T62 (well worn)
  • scottie3158
    • 14583
    • Holbeach
    #136
    Si,
    You never cease to impress.
      • 16196
      Hi Simon
      You really are a master scratcher. As scottie says "You never cease to impress."
      • rtfoe
        • 9208
        • Richard
        • Shah Alam, Malaysia
        #138
        Ye Gads!! Simon, where's the plastic?? :tears-of-joy: I'm already exhausted just reading through all the scratchery...almost licked the screen too 'cos of the green stuff. :smiling6::thumb2::thumb2::thumb2: Now doing the David Copperfield thingy...
        • outrunner
          • Apr 2019
          • 2420
          #139
          Marvelous work there Simon, a joy to behold.
          Andy.
            • 22954
            #140
            Some great work Simon.
            • Steve Jones
              • 6615
              #141
              Another lovely update Simon. Are the bump stops staying as is or are you adding the rubbers as well?
              • SimonT
                • 2824
                #142
                Hi Joe - thank you very much
                Scottie - impressive, not really, daft, definitely especially when I have a perfectly good Trumpeter 62 sat here
                Jim - see above :rolling:
                Richard - there are still one or two bits here and there
                Steve - possibly a misleading use of the term, track bump stop seemed as good as anything but maybe track skid would be better. They are just steel plates that curve up at each side into a flat U shape. Due to there being no return rollers, and the running of a fairly slack track, once they are at speed and start manoeuvring the tracks tend to flail about - the skids stop the vertical track movement and the subsequent destruction of the track guards
                Did a very small amount last night
                there should be a small grille on the right of the engine deck - missing of course in the kit but present in the Eduard set
                so, drilled a couple of holes through the deck then opened out with a knife
                grille installed with a couple of bolt heads added to the positions marked on the etch
                I also added the radiator louvre panel which goes on the inside of the hull below the holes in the deck
                Had to modify it slightly by trimming the ends off as it fouled on the reinforcement that I had installed to keep the various hull sections together
                I also installed the Eduard mesh over the radiators but then removed it as the mesh pattern was too fine
