Hi all
So this was another thing that Junior and I started back in February but I only finished the build at the weekend.
All in all a very nice kit with no flash and nicely detailed without being stupidly complicated and the instructions are very nicely done too!
I replaced the plastic barrels with metal ones, albeit it wasn't necessary to use all of the barrel as they seemed to have also been designed with standalone AA guns in mind, so I just snipped them off at the appropriate point on the barrel. The shot below does though show the barrel fully completed as an FYI. The picture below does not do them justice!
The only problems were entirely of my own making - the most obvious one being that I have had to glue the guns in place so they can no longer elevate...don't ask....
. The kit also comes with some photo etch side mounted sand skirts, although from what I've found online these were not seemingly fitted for use in Normandy. The tracks are single piece mouldings although it was necessary to glue in one sod the road wheels, sprocket and front idler.
Again, I'm hoping that this will see coat of primer at the weekend!!
ACW as usual.
ATB
[ATTACH]378547[/ATTACH]
[ATTACH]378548[/ATTACH]
[ATTACH]378549[/ATTACH]
[ATTACH]378550[/ATTACH]
[ATTACH]378551[/ATTACH]
[ATTACH]378552[/ATTACH]
[ATTACH]378553[/ATTACH]
[ATTACH]378554[/ATTACH]
[ATTACH]378555[/ATTACH]
[ATTACH]378556[/ATTACH]
. The kit also comes with some photo etch side mounted sand skirts, although from what I've found online these were not seemingly fitted for use in Normandy. The tracks are single piece mouldings although it was necessary to glue in one sod the road wheels, sprocket and front idler.Again, I'm hoping that this will see coat of primer at the weekend!!
.ACW as usual.
ATB
