Mirage Models: 1:35 Wyrzutnia Stuka Zu Fuss (UE-sWG 40/32cm Wk Fl)
I'm looking to build the Renault UE basic model later this year so interested to find out how the kit goes together. Good luck -
Some build progress pics - craft knife blade to give some scale...
The general fit is goo with little flash but some sinkage on a couple of smaller parts.
The biggest gripe is the number of proportionally huge ejector pin marks - on the mudguards they were almost a third of the width and around 2mm proud of the surface.
The holes for the return rollers on the side of the hull are far too small and needed reaming out.
be careful with the triangular plates B25 and B24 - I got them mixed up and glued them in the wrong place so had to cut off and re-glue.
The exhaust outlet was just a blob so I cut it off and replaced with some alloy tubing
