Why on Earth would you scratchbuild an M113 in 1:35 scale?
    M113 kits abound, from the old Tamiya through to the modern AFV Club. Why on Earth would I then go to the trouble of doing this?
    [ATTACH]388904[/ATTACH][ATTACH]388905[/ATTACH][ATTACH]388906[/ATTACH][ATTACH]388907[/ATTACH]
  • Gary MacKenzie
    SMF Supporter
    • 1059
    • Gary
    • Forres , Moray , Scotland
    I guess because you can ..... me , not so much.
      Not because I can, no. There’s a deeper reason, which will become clear as this build goes on
        • 16309
        You're a masochist, you like a challenge, you've been drinking or maybe all three.
        Looking forward to the real reason :thumb2:
        • Jon Heptonstall
          • 1706
          You have a cunning plan.
          Hurry up and tell us.
          Jon.
          • Mini Me
            • Jun 2018
            • 10711
            Matron hasn't given him his meds yet and he's off his "NUT":tongue-out3: Rick H.
            • Gern
              • 9307
              And me ..... not a hope in all the seven hells!
                • 19134
                Only reason I can think of is that plasticard has a use by date that I wasn’t aware of.....
                  No; depends on what it is; never; and no
                  I’m trying to think of ways to stretch out the reveal for as long as possible while still posting pictures of the build …
                  So cunning that after building the above, I actually wish I’d bought a very cheap (say, second-hand) M113 kit instead of the AFV Club one can you see the hull of in the first photo.
                  See above :tongue-out:
                  Been that for ages. There’s no cure, you know.
                  I didn’t see one on the label that’s on the sheets I used, so no, not it either …
                    I made the cover that sits over the suspension mounts and torsion bar anchor points:
                    [ATTACH]388935[/ATTACH]
                    It’s just 2 mm square plastic rod with 1 by 3.2 mm plastic strip, so simple enough to make.
                    And I made this for the right-hand side:
                    [ATTACH]388936[/ATTACH]
                    • Jon Heptonstall
                      • 1706
                      Am I close if I said Tan Son Nhut?
                      Jon.
                        That’s presenting me with a puzzle now, what the connection between Tan Son Nhut airbase and M113 is, that you’re referring to
                        • Jon Heptonstall
                          • 1706
                          • Jon Heptonstall
                            • 1706
                            Hi Jakko.I was thinking of this photo.
                            Jon.
                              Ah, I see now I did find that photo when I went looking for what you might have meant this morning, and wondered if that’s the one you meant. But for that, a regular M113 kit would do quite nicely, with a hole cut in the front and roof plates …
