Airfix 1/35 M36B1Gmc tank destroyer "abandoned"
  • peterairfix
    • Jul 2012
    • 11145
    Not really my thing but I thought I would drag out of mothballs and show you what's been done. Click image for larger version
ID:	1139574Click image for larger version
ID:	1139573Click image for larger version
ID:	1139572Click image for larger version
    If I may give a few tips? The little flaps over the periscopes, in the drivers’ hatches, should be at about a 45 degree angle, so they sit right on top of the periscopes themselves. On the real thing, these are spring-loaded so they get pushed up by the periscopes and snap shut again when those are removed. The rear hull plate seems to be at a very strange angle It should be up against the vertical rear edges of the side plates.
    Did the kit come with those etched headlamp guards?
    • peterairfix
      • Jul 2012
      • 11145
      Originally posted by Jakko
      If I may give a few tips? The little flaps over the periscopes, in the drivers’ hatches, should be at about a 45 degree angle, so they sit right on top of the periscopes themselves. On the real thing, these are spring-loaded so they get pushed up by the periscopes and snap shut again when those are removed. The rear hull plate seems to be at a very strange angle :smiling3: It should be up against the vertical rear edges of the side plates.
      Thanks for those pointers this is why I rarely build tanks but am I right in thinking that this is a reboxing of another company
        As far as I know, all the current Airfix 1:35 military vehicle kits are reboxed Academy. I have the Academy M36B2, and I suspect the turret sprues are the same between your kit and mine The difference is that the basic M36 had a different upper hull, with sloping sides, and the M36B1 like you have, used a standard Sherman hull instead. The M36B2 had a wider suspension — which Academy have missed on their kit, apparently falling into the old trap that the armoured roof is what makes it a B2.
        • peterairfix
          • Jul 2012
          • 11145
          I am going to abandon this build as I just can't get on the tanks of any sort so I will be putting it up for grabs in the correct section.
          • spanner570
            • 15599
            That's a shame, Peter. I guess it happens to us all at sometime or other, but re-reading the thread thus far, I don't really blame you.....
            Onwards and upwards.
