Hi this is my next build I've totally lost interest in Toon tank at the moment there's not the internet that there was, I've been building them for over 2 years straight.
So seeing if I can still build a real model.
Cleaned up all road wheels/support track rollers, fitted poly caps and glued together.
Fitted front rear axles, 2x floor hole caps, filled the gaps above rear idler wheels using white card.
Fitted all parts to rear panel adding two hinges to stowage bin, fitted rear panel to main lower hull.
[ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH][ATTACH=CONFIG]n[/ATTACH]
