It's taken a time to complete the print of this! I bought the files at the beginning of August
The bridge parts will be treated as a separate model/ The part I had difficulty with was the 'A' frame. bottom left - I eventually succeeded at the 7th attempt. It was a matter of finding the correct orientation for giving the best detail with supports that could be removed without breaking the part!
For some reason, I thought that the bridge was deployed using hydraulics, but it is actually screw driven.. The giant gearbox ( bottom middle ) pushed the threaded rod backwards & forwards. pivoting the 'A' frame about the front glacis plate. I still haven't worked out how the bridge is unfolded, I suspect cables!
Instructions?
That's it - I haven't printed the small pins, I'll make those with something a bit stronger. The illustrated model is slightly different, it has separate 'fenders', whilst mine has them incorporated. The parts needed varying degrees of clean up, from minimal ( tracks ) to tedious ( gearbox ) Now it's a matter of using the CA to get the bits to stay together.........................
Instructions?
