1/35 scale Rheinmetall Mk 20 RH-202 2x20mm Hellenic Army
towed anti aircraft system model by Hecker & Goros
Lucky me, I managed to shot few pictures and keep in mind few things for (future) scale modelling projects too. Since this article is about the Rheinmetall Mk 20 RH-202 2x20mm scale model, have a look on few pictures of that day.
The Rheinmetall Mk 20 RH-202 20x139mm AA system can be transferred after placed on two-wheeled trailer. It and can be coupled to a light vehicle such as the Mercedes Benz 240GD Geländewagen , or a military truck such as the Mercedes Benz Unimog or the Steyr 680M - all of them are in service in the Hellenic Army & the Hellenic Air Force.
Two versions of the Rheinmetall Mk 20 RH-202 AA system received by the Hellenic Army under special order to cover the anti aircraft Artillery demands. The main visible difference between these two versions is the iron sight or the telescopic sight (used for pre-aiming) placed over the main Officine Galileo R-56 computerized sight eyescope. These two versions differ (apart from the obvious visible difference as explained before) a few more external details on the electronic control switches. Both versions can also be electronically connected with the S-11 simulator (see following picture), used for AA gunners daily exercise.
