Something a bit different boys!
This 160 odd piece 1/6th MG42 Dragon kit is very well engineered, with loads of detail and 'working bits'
The down side are the instructions. Apart from a split drawing of the rear angle adjuster, the rest of the kit instructions consist of blurred images of the built model, with arrows pointing to where the relevent bits go....This means dry fitting around six pieces at once, (including miniscule springs) to get the correct sequence for glueing and more to the point on this model where not to glue! Then trying to remember the correct way with all the bits loose in front of you.....
There are quite a few parts not used and some supposed to be, but for the life of me I couldn't see where, as the instructions forgot to mention them anyway!!...Follow that!
I tried to get the pictures in line a second time, but failed. So rather than go to embarrassment
of asking the mods to delete this thread a second time, I've gone for en-mass pictures.
O.K., the build:-
In sequence. The box art / The instructions ( note the only bit of 'exploded' diagram) / The tripod rear vertical angle adjuster thingy with collapsable hinges. / The rear telescopic sight and adjuster fixed to the top of the tripod cum gun rest. / The three main top parts. Note the calibrated horizontal gun slide on the left hand piece. Finally, the three components fixed together.
The finished thing is all hinge pins and goes up and down, side ways and folds flat! It is really complicated and I reckon a bit fiddly in the field and easily 'bent'!
That's it for now. Next comes the telescopic tripod legs, which are part brass tube and part plastic...and more bl***y diddy springs!
I hope you like this slight move from the norm.
Ron
[ATTACH]50395.IPB[/ATTACH]
[ATTACH]50396.IPB[/ATTACH]
[ATTACH]50397.IPB[/ATTACH]
[ATTACH]50398.IPB[/ATTACH]
[ATTACH]50399.IPB[/ATTACH]
[ATTACH]50400.IPB[/ATTACH]
[ATTACH]50401.IPB[/ATTACH]
[ATTACH]50402.IPB[/ATTACH]
[ATTACH]50403.IPB[/ATTACH]
O.K., the build:-
Ron
