Scotties Sd.Kfz. 10/5
  • Airborne01
    • Mar 2021
    • 4371
    • Steve
    • Essex
    #46
    Originally posted by Jim R
    Ain't that so often the case. Iffy instructions with imprecise location points and then positioning of other parts is thrown out.
    You have overcome issues and it all looks good.
    Can't help with the windscreen question but someone will know. Calling Jakko :smiling: :thumb2: :smiling:
    Don't remind me please ... I've got to attack my beastie again this weekend :thinking: :flushed:! Looking good mate - and yes, there is plentiful photo evidence of screens being removed both from damage and as a camouflage measure. Mounting points often still exist though, or the screens may be covered in hessian or cam net. Crack on Guv! :hugging-face:
    • scottie3158
      • 14638
      • Holbeach
      #47
      Originally posted by Jakko
      Look at it this way: even if the windscreen were normally still on the vehicle, chances are that individual crews would have removed them for exactly the reasons mentioned.
      Jakko, I think your right the screen would have been removed.
      Nice Paul, gives me and many more hope when you find something doesn't fit property, mind I can get any part to miss fit !
      John, that is the challenge I enjoy when building the older kits.
      [/QUOTE
      Steve, the removed option seems to be the one in favour. I'm looking forward to seeing your progress.
      • scottie3158
        • 14638
        • Holbeach
        #48
        As the general concensous was for no windscreen that is the way I went. I decided to scratch the armour from evergreen sheet as the kit offering was over thick and not very well moulded. So each of the panels was cut using the kit ones as guides. I found some pictures although not very clear on the inside of the armour. It appears the vision blocks were just simple plates that could be slid open or shut. The side plates had some rivet detail but nothing on the inside so using SWAG (Scientific Wild Arse Guess) I summised that this was for the plate supports that fixed it to the vehicle body. Next the rivet detail was added.
        Even though this follows the kit parts this would have been a drafty vehicle as the armour leaves large gaps between it and the body.
        Anyway enough waffle,
        comments welcome
        Scottie
          • 16311
          Hi Scottie
          Well right or wrong it certainly looks right. Don't concern yourself with it being a bit breezy inside - those Germans were a hardy bunch
          • scottie3158
            • 14638
            • Holbeach
            #50
            Hi Scottie
            Hi Jim, also the rest of the vehicle is open to the elements, so I guess it didn't really matter.
            • minitnkr
              • 7809
              • Dayton, OH USA
              #51
              The wind chill isn't too bad if you keep it under 20mph.
              • adt70hk
                • Sep 2019
                • 10554
                #52
                Great work Paul. Just had a catch-up. Very impressive indeed.
                ATB.
                  Could you please stop this amazing work as it's embarrassing to us lesser mortals Paul .:upside:
                  Great detail , looks really good .
                  • Mini Me
                    • Jun 2018
                    • 10711
                    #54
                    Hi Scottie, just checked and found a photo (on "Kfz Der Wehrmacht" website) showing the armoured shield from the rear......no wind screen evident. Sorry I don't know how to do the url thing but it's an easy site to navigate if you want to check it out. Rick H.
                    • scottie3158
                      • 14638
                      • Holbeach
                      #55
                      ATB.
                      Andrew thanks mate I'm enjoying it so far.
                      Thanks John, I try.
                      Rick,
                      Thanks for that mate I will look it up.
                      • Graeme C.
                        • 1628
                        • Graeme
                        • UK
                        #56
                        The armour looks good Paul, the visors with their sliding brackets are nicely done.
                        • Steven000
                          • Aug 2018
                          • 2949
                          • Steven
                          • Belgium
                          #57
                          Very nice job so far Scottie :thumb2:
                          Steven
                          • scottie3158
                            • 14638
                            • Holbeach
                            #58
                            Thanks Graeme, not sure if they are accurate but hopefully look ok given a quick glance.
                            Steven
                            Cheers Steven, still lots to do.
                            • scottie3158
                              • 14638
                              • Holbeach
                              #59
                              Progress is painfully slow, as not much bench time at the moment. Added some details to the front. The headlamp mounts had no detail at all just simple moulded overscale tubes to affix the light to. So they were shaved off and the details added from pewter, foil and copper wire. Hopefully they look ok.
                              cheers
                              Scottie
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #60
                                Nice!! :thumb2:
