Lee Drennen’s 1/72 German Captured Ford G8TA Cargo Truck.
  • Lee Drennen
    • 7738
    Going to try to pull this off a PST Ford G8TA using a Heller/Airfix Opel Blitz chassis and running gear for a captured German truck. I’m using the single axle frame the for another build so I was left with the cab and complements.
  • Lee Drennen
    • 7738
    Frame is ready to be lengthened. I’ll straighten up the pintle hook later. Click image for larger version
ID:	1166712Click image for larger version
ID:	1166713Click image for larger version
ID:	1166714Click image for larger version
ID:	1166715Click image for larger version
      • 16165
      Hi Lee
      An interesting build. I hope you don't run into too many fit issues putting the two kits together. So far it looks spot on.
      • scottie3158
        • 14577
        • Holbeach
        Lee,
        Now that's an interesting build.
          • 19104
          Nice kit amalgamation here Lee. It will give you a unique vehicle. Top job :thumb2:
          • adt70hk
            • Sep 2019
            • 10540
            Looking good Lee, hope it doesn't prove too troublesome a build process.
            ATB.
            • Steve Jones
              • 6615
              Same as what the guys have said. Keep it coming my friend
              • Lee Drennen
                • 7738
                Originally posted by Jim R
                Hi Lee
                Thanks Jim I think I have it beat into Submission it’s been going good so far.
                • Lee Drennen
                  • 7738
                  Lee,
                  Paul. Glad you peeked in. You can Thank Rick H for the inspiration from his 1/87 collection he has.
                  • Lee Drennen
                    • 7738
                    Thanks Tim for dropping by. Yes it will I’ve seen just one pic so far that had the Front Wheel Drive it will be different
                    • Lee Drennen
                      • 7738
                      ATB.
                      Thanks Andrew I think I have the hard part over
                      • Lee Drennen
                        • 7738
                        Thank you Steve glad your looking in on this.
                        • Mini Me
                          • Jun 2018
                          • 10711
                          You have made a lot of progress since I last looked in.....keep it coming. Rick H.
                            Nice mix there Lee, good for you trying it .
                            • Lee Drennen
                              • 7738
                              Thanks Rick. The frame is cut into and I repositioned the front and rear wheels letting them set up good before moving on.
