Si-B’s Dragon 1/35 Sd.Kfz. 10 Ausf. A + Dragon 10.5 cm leFH18/40
  • minitnkr
    • 7785
    • Dayton, OH USA
    #16
    Very nice builds. Aren't those PAK 50mm ammo boxes? I think 10.5cm IeFH 18/40 were two part ammo. crated.
    • David Lovell
      • 2186
      #17
      You know me Si if it looks good then it is good from what I can see mate bloody excellent well done that must have been a epic journey to get this far inspirational im off to fiddle with some 72nd plastic ,looking forward to the next update Dave
      • Mickc1440
        • 4849
        #18
        Very nice build Si, that base coat certainly enhances its look
          Originally posted by Si Benson
          The eagle eyed among you would of spotted the Sd-kfz 10 came with a 5cm Pak 38 but I had the 10.5cm leFh 18/40 in the stash and wanted to use that instead.
          I’d think this would be an emergency thing only. The Sd.Kfz. 10 was a 1-tonne halftrack, meaning a pulling power of one tonne (cross-country). The 10,5 cm le.F.H. 18/40 weighed just under two tonnes, so it would have been doable but not easily. Still, if the enemy is approaching and all you’ve got is a one-tonne halftrack, you’ll use it to tow that two-tonne howitzer.
          • Si Benson
            • 3572
            #20
            Thanks for your kind support gents :thumb2:
            So as was mentioned, the 5cm ammo boxes on the fenders were incorrect for the gun as I had decided to swop it.
            As the boxes had been mounted on to photo etch pieces, they came off quite easily….just had to use a little CA remover to clean it all up.
            Unfortunately it left bare plastic….
            Broke out the airbrush and Mr surfacer black primer, followed up with Tamiya German grey.Click image for larger version
ID:	1230766Click image for larger version
            Also started painting up the tools and other bits. Still plenty to do :smiling4:
              Nice fix, it doesn’t look like it’s visible at all that you removed parts there.
              • Airborne01
                • Mar 2021
                • 4298
                • Steve
                • Essex
                #22
                Loving it so far mate! I'll make mine one day!
                • Airborne01
                  • Mar 2021
                  • 4298
                  • Steve
                  • Essex
                  #23
                  Look forward to the make-up results! Grey or Sand?
