Your Impossible Builds...
  • Bigfoot57
    • Jun 2015
    • 1103
    #16
    Tony
    Interesting idea I have heard of foam but didn't know it could be purchased in cans as the only stuff like that I had seen was that cavity wall insulation foam which is probably more lethal than agent orange used in Vietnam will definitely investigate as a possible method
      I keep eye balling the 1/48 Planet models resin JU-388 in my stash ,open the box look at it,sigh mornfully and put it back. Just ca'nt get my nerve up to pull the trigger on it .
      • dave
        • Nov 2012
        • 1844
        • Brussels
        #18
        Originally posted by \
        My impossible build although I'm going to give at go when I've done some research is to show a Saturn V launch I've no idea how to model the exhaust gasses plumes or the water bowsers on the pad and the resulting steam clouds
        I have the model and the launch tower is currently under construction just need a interface between the two ie the rocket about halfway up the tower rising on 5 F1 Rocketdyne motors I want to put some dynamic into this build not just have it static on the pad
        I have seen good results with teased out cotton wool, painted/dyed in various colours so yellows at the hottest parts to pale greys further out. Even LEDs in the centre to give the brightness.
        • Bigfoot57
          • Jun 2015
          • 1103
          #19
          Yep that's one of the ideas I've been kicking around the material is light lends itself to being manipulated should be easily colourable using paints/dyes for the immediate stress plumes directly from the engines something like a clear plastic bottle neck suitably painted will need 5 of them then attach the cotton wool cloud to the 5 exhaust plumes that's the theory will need a bloody good paint job to pull it off convincingly
          Colin
