For flock sake ;-)
    For flock sake ;-)
    I have seen on youtube that most use enamel flat black before applying flocking, I have tried acrylic's and pva as I don't want to use an enamel paint but it looks terrible! Does anyone know of a different liquid that you can use that doesn't need cleaning with spirit?
  • eddiesolo
    • Jul 2013
    • 11193
    This is a 1/144 scale I did flying above just above the ground, the grassing is all applied with a base coat of PVA and then sprinkled on. For larger scale dios I then wait until dry and then blob some PVA and clump the grass.
    You should be okay with PVA so not sure why you're having issues.
      [ATTACH]260604.IPB[/ATTACH]
      [ATTACH]260605.IPB[/ATTACH]
      [ATTACH]260606.IPB[/ATTACH]
      [ATTACH]260607.IPB[/ATTACH]
      [ATTACH]260608.IPB[/ATTACH]
      [ATTACH]260609.IPB[/ATTACH]
      I think Mark is referring to the flocking for car interiors Si.
      But if an enamel base provides the best finish, why not use that? It's not as smelly as most would have it.
      Failing that, how about going over a coat of acrylic with a gloss varnish? Leave it for 48 hours for a hard, smooth surface.
        Yes its for car interiors Patrick, how heavy do you lay on your pva Si?
        • monica
          • Oct 2013
          • 15169
          hi Mark,just use a mix of 50/50 water ,PVA,glue,paint it on,so ,what ever it is, is covered ,then shake the flock on,
          so it is covered and looks even,don,t worry if you use to much,,you can shake it off later on,
